Foolproof sharpening of card (cabinet) scraper
As promised, here is a foolproof method of sharpening a card (in USA) or cabinet (everywhere else) scraper.
Step1: flatten both sides of a the card. I use a well worn 600 grit Eze-lap diamond stone. This is 10 years old and now the equivalent of about 3000 grit.
Step 2: use a magic marker along one edge (texta to us Aussies) to ensure you get it all.
Step 3: Once both sides are done (I do all 4), it is time to square the edge on the diamond stone. Use the magic marker again.
Step 4: This is the point where many think that they have done enough. They run the card over the wood (here, softish quarter grain Tasmanian Oak). Nothing but dust ...
Step 5: Use a proper burnisher. Not a screwdriver shaft - too soft to do a damn. I use a carbide rod.
Step 6: Draw out the steel. This is one of the vital ingredients. You want to pull the steel outwards with the burnisher. You will not create a proper hook without doing so. About 5 strikes from the left and 5 from the right.
Step 7: Turn the hook at about 5 degrees. Do the 5 and 5 again ...
Step 8: This is another crucial omitted step - do it again but at closer to 10 degrees.
Step 9: Now take your shavings!
BONUS: I made the following out of the end of a 3/16" thick O1 plane blade. It must be flat (as above).
Take it to the grinder (mine uses a 180 grit CBN wheel) and create a hollow around the edge.
And you are done ...
This is the most amazing tool for shaping or rapid removal of waste. It does not provide as smooth a finish as the first scraper, but it works so much faster.
I think probably not, but it might be useful to just throw the idea out there. For those who might not immediately recognize it, this scraper is a turning tool.
