Felt it or Flock it???
Alan Young
Alan Young
I am just about finished with a game table. The table's top surface can be removed and will reveal a lower surface design essentially for assembling puzzles. That surface and the two drawers are to be covered in felt...
I have done this before-covering drawer insides with felt but have not been real pleased with my techniques or results...for example you can see some unevenness in the edges of the red felt in this drawer-
Not quite as easy to see here but the edges between meeting surfaces are not real "clean" here either.
I did a search on flocking and the technique and results all seemed admirable- except all the videos and articles I found where the "Painted Glue" was applied were for small boxes and the flocking could be shaken on to the surface before the paint/glue began to set. The drawers I have to work with are aprox 17"w, 15" deep and 2.25" high- I am afraid the paint/glue might start to set before I was ready to shake on the flocking--
here is one of the drawers I need to cover with felt or flocking---It is only pulled out a tad out from the table--
Any suggestions on a way to proceed?
Re: Felt it or Flock it???
I can't answer your question, but have another - have you considered leather?
Alan Young
umm  Intersting thought....Have not
Alan Young
I will see what that could mean-At first though it seems leather would be easier to cut for an accurate coverage-the felt stretches and bunches...
mdclor
Alan, I can't tell from the pix but if you are getting rough edges it makes me wonder how you are applying the felt. I was taught to cut pieces of cardboard to the size needed less 1/8". Then cut the felt 1" larger than needed for all 4 sides. Apply spray glue to the face and the back edges to the cardboard, then apply the felt to the face and wrap the ends over the edges and put a heavy weight on it until the glue sets. Oh, you should trim the corners of the felt at 45* before the glue step. That way when you fold it over it meets without any overlap.
Also, you might consider using ultra suede for the fabric.
Suede
Grant in Iowa
I have tried felt, flocking, and suede on various projects. Here are my thoughts:
Felt typically looks cheap. Maybe I haven't found the right product, but I haven't liked the results much when attempting higher end work.
Flocking is the way to go on smaller drawers, and drawers where the sides are to be coated. Simple, good results. Not sure how well it would work on a larger drawer. Also, wear could be an issue on a well used project.
I have also used suede. Available from Tandy leather company, among others. I visited their store in Texas and bought a suede economy split in royal blue, and have used it on many box linings and one drawer lining. I was able to use spray adhesive and adhere it to the drawer bottom before assembly, making the drawer bottom kerf slightly wider to accomadate the added thickness. Excellent results that garnered positive comments from fellow woodworkers. This is my preferred method of lining drawers now. Beautiful stuff.
Along the same lines, you might consider using other leather products. Since leather has fallen somewhat out of style, it can be had for a reasonable cost.
Here's a pic of blue suede in a box:
garthinsandiego
Have used both the adhesive-backed felt over cardboard and the flocking techniques. Both provided acceptable results on smaller (up to 12" x 14") projects. The flocking is applied with what appears to be a similar colored oil-based paint. That dries fairly slowly (like oil paint) and if the result is uneven, you can re-coat with the adhesive/paint and apply more flocking. I have done this with good results. I cannot comment on the durability of the resulting finish as none of my projects have received much wear and tear. My guess is that it is less durable than felt.
All my best ideas were stolen by the.....
craftsmen who went before me.....
I was going to suggest cutting the groove for the drawer bottom wider to accommodate the thickness of what ever. You could use screws to attach the rear of the bottom so that some day it could be removed for repair or placement.
And I have used the cardboard Idea as well in jewelry box drawers, covering it with velvet.
Agree...
John in NM
Sounds like the correct technique to me, though I also like Grant's method with the suede.
John in NM
One thing about felt, it only looks cheap if it is cheap - that poly-whatever green crap from the local craft store.
Proper woven and felted wool fabric - that one finds on pool tables for example - is wonderful stuff. Expensive, but well worth it for a classy look.
I'm a fan of the felt camp
Gary Smyth
You might want to check out book binding techniques and bindery products I've been taught the cardboard method and to wrap the edges to get a tight fit. I've found that spray adhesive is messy but a product "Aileen's Tacky Glue" found in craft stores and fabric stores works well and does not bleed through fabric. With cardboard base you can pull out the liner if you paste/glue in a cloth ribbon on the bottom before setting it in the drawer.
William Duffield
If you want a traditional cloth covering, maybe you should be using baize instead of felt.
For more information, Jack Plane has lots of good advise on his Pegs and 'Tails blog.
https://pegsandtails.wordpress.com/?s=baize
Dick Coers
I use 1/8" hardboard instead of cardboard, but it's the best way to line a drawer or jewelry box. If you cut it 1/16" total, it's a really nice snug fit. It will take a pliers to take it out.
Alan Young
Great Info-Thanks
Alan Young
The drawers I showed are no where near me. I can't totally recall what I did and I can't exactly tell from the photos-I believe I used spray adhesive on the drawer bottom of the music cabinet drawer-I think I used two sided adhesive tap on the chess piece drawers-Either way my technique needs improvement if I go with felt or suede --The flocking intrigues me but I'm leary of it's ability to hold up over time so I will be looking at the alternatives suggested here..
Thanks again my friends-I'll post finished pictures when I'm done-
-Alan
More suggestions
I agree with the cardboard method, Alan. If you like, make cardbaord pieces to fit the sides of the drawer, too. Hold them in place with some spray adhesive after the bottoms are in.
As for materials, I've tried them all but I actually prefer velvet. I once considered the flocking stuff and decided it would look cheap and wouldn't hold up in use, plus it's irreversible. I defer to those who have found differently.
For the chess pieces, I'd suggest French fitting them. Make a cutout board of wood or styrofoam to fit the pieces and then glue in a stretchy fabric or silver cloth. You could simplify by making recesses for, say, eight pieces at a time instead of individual recesses. I'm not an expert on this, but there are lots of resources out there to help you through.
Clint Searl
Check out Ultrasuede
del schisler
i have used the suede flock for yrs now, i got the canaster sprayer for the flock, cost a little but i make 100's of box , they also have a other way with the card board thing also which would would work faster than just hand doing it, the dry time i am sure would be fine with that one , here is the link , call and ask about the dry time, i let mine set over night and than use little air and blow the loose out the link and a pic of the mini flock tool http://www.flockit.com/index.php/order/rayon-suede-tex-fibers.html
Alligator Hide
Alan,
I mean really.....felt? flock? Get serious man. You want to go for durability!!! And nothing says "durable" like alligator hide! Get with the program man!
Your Pal,
T
You're right!
John in NM
I'm going to line my chisel drawer with it! :D
'course, first, I have to have a chisel drawer :D
Chemicals in hides?
Dick Coers
Just wondering if there are tanning chemicals in hides that might not treat steel well.
How are you felting
I have never felted but I have lined with velvet. I stretch and glue with contact cement the velvet over poster board and then insert.
Re: Chemicals in hides?
John in NM
Actually, I was kidding, 100% non-serious reply.
However, I don't think the tanning chemicals hurt steel much. The hydrophilic nature of leather itself might not do them any good though.
Rum
Chrome tanned leather reportedly has some retained salts that hasten corrosion as well. Vegetable or oil tanned isn't as much of a problem in that regard (but as you note there is the hydroscopic nature of leather to deal with).
How significant the problem is would depend on the type of steel, type of leather, environment, etc.... and I haven't seen anything really quantifying it (if anyone knows of something would certainly be interested to see it).
Alan Young
OK-You hook 'em I'll shoot 'em
Alan Young
http://www.history.com/shows/swamp-people/videos#
