Old planer, big improvement
John in NM
Here's the old planer:
Nice 1960's or older PM 100 12" planer. Old but lightly used, still has the screw jack blade adjusters. I bought it used maybe 15 years ago.
Here's where the improvement comes in:
Kinda giving it away since you can see the box... :D
New cutterhead installed:
Had new bearings put on too, cleaned and regreased the gears, planer is now super quiet as planers go, and only makes a slight buzzing noise when cutting.
Trying to figure out now what to do with my two sets of 12" blades. Might just have the sharpening shop cut them to 8" for my jointer.
Re: Old planer, big improvement
Adam of Oakland
hooray!
Adam of Oakland
sweet! yep, after running a lunchbox planer with 3 straight knives, when I upgraded to a segmented head stationary unit, i was gobsmacked.
Truly if there's a machine in my shop that saves my bacon, it's my thickness planer. opened up so many doors for me.
glad you got the cutterhead. now make some shavings!
Re: hooray!
McKay
cut the pieces and make a sweet scraper tool.
William Duffield
What? You're not going to put a Shelix head in your jointer, too? That planer will spoil you, and you'll soon be sorely dissatisfied with the noise, quality of cut and maintenance of the jointer. A new head for it is a lot less expensive than the planer head.
You can cut the old blades up and make them into marking knives, Sloyd knives, chip carving knives, chisels, etc. (yes, and scrapers, too).
Lots of good uses there....
John in NM
I think I can cut them at 8" and the 4" drops will still be useful for most of those projects.
One day I may do the jointer too, though it may actually be harder to work on than that planer. Took all of 45 minutes for dis-assembly, maybe an hour to re-assemble. Those old PM's were well engineered machines.
mdclor
John, I agree that you should get a new head for your jointer or even go whole hog and get a brand new jointer. :D I can be very good at helping other people spend their money. haha
Re: Lots of good uses there....
William Duffield
The new ones aren't so bad, either. I recently obtained a used PM 15HH that I am quite pleased with. My DJ20 is next in line for a heart transplant. Finding uses for old blades is not a problem, but what to do with the old cutter head is. Maybe I can make it into a base for my shop clock?
You've seen my cars...
John in NM
I like old stuff :D
I may do the head in the jointer though. I have a line on a 12" jointer and if that doesn't pan out I might improve the 8" a bit instead.
Now, you're talking!!!
