A Job
Ronald,
From what I've seen of that machine, the motor and drive pulley are on the opposite side of the frame from your lower band wheel. Thus it appears that you will have to remove the motor and the drive belt pulley before you can even start to get to the bearings. Get them off, then remove the large wheel and you'll be in position to remove the drive shaft. depending on design, it will remove from the front or the back and needs be pulled "through" a bearing on the opposite side. getting both bearings out is likely to be a fight, and there's no guaranty that their size/type markings will survive the effort.
I suggest you find info on and a source for the replacement bearings before you dive into this lest you wind up with just a bunch of parts on the floor and no saw.
