Compatability question
Gordon
Will the accessories offered for the Tormex grinder fit my Grizzly 10 " wet grinder?
I was mainly interested in the diamond stone dresser that Tormex has
to dress their stone.
Thank you.
Gordon
Re: Compatability question
I have the older Tormek w/ the diamond dresser.
I see no reason why the dresser wouldn't be compatible w/ the Grizzly T10010 10" wet grinder. This does make one assumption - that the "universal support" on the Tormek is the same as the one for the Grizzly.
fredhargis
I have the older Tormek, as well as the Jet wet grinder. The bars on both are 12MM, which is the size Grizzly shows on their model. I use the Tormek stone dresser attachment on my Jet, but I had to make a jig for it to work. The stone dresser grips the upright post of the tool rest to keep it steady while truing the surface. On a Jet the post is located further away from the wheel, so some provisions had to be worked out. In looking at pics of the Griz (which I've never seen first hand) the post upright appears to be about as close to the wheel as the Tormek is...I have to think it work just fine out of the box.
Where do you live? Maybe someone close with a Tormek would let you try before you buy.
If you ask Sir Google politely to lookup "grizzley tormek" he will present some reviews and threads that discuss this, for example on sawmill creek. I didn't read all of them but in the one I looked at someone stated:
"I have the grizzly sharpener, and several of the Tormek jigs. The Tormek jigs are 100% compatible with the Grizzly. So are the Jet jigs, but I would avoid them, they are not nearly as well designed."
I have used my Tormek for many years and have worn out several wheels, mostly while dressing with the diamond jig. I have ordered a CBN wheel from Ken Rizza. We'll see how it works out.
http://woodturnerswonders.com/collections/cbn-wheels/products/tormek-cbn-wheel-600-grit-10-x-2-inch-1-2-inch-arbor
Please report back on the CBN wheel
Dick Coers
Anxious to see how the CBN cuts at that speed, and how much more course the grind will be.
Re: Please report back on the CBN wheel
I will. I ordered the 600 grit; they can make it with any grit. I plan to do coarse shaping on a CBN wheel I mounted on a separate grinder. (It works extremely well)
They do offer a Tormek wheel with 1" of grit on each side of the wheel - that's the one I ordered.
