I am making new doors and drawer fronts for the house I am working on. I am making Mission style or perhaps Shaker style frames and flat panels and they will be painted white. Using poplar I rescued from a road widening project and had sawed several years ago and air dried. Altogether there are fifty panels either drawers or doors from the kitchen or vanities. So there are 250 pieces including the plywood panels.
The question is, is poplar an irritant? I am hacking and coughing. I wonder if it is my BP medicine or the poplar or something else? I had a cough when I started this brand of BP meds but It has been controlled with Zirtec.
Allergies/Toxicity: Although severe reactions are quite uncommon, Poplar has been reported as an irritant; usually most common reactions simply include eye, skin, and respiratory irritation, as well as asthma-like symptoms. See the articles Wood Allergies and Toxicity and Wood Dust Safety for more information.
I'm also reminded that regardless of the reported toxicity, different people are sensitive to different woods. One thing I discovered by accident (when wearing a wrist watch and sanding ERC) will test your sensitivity to a particular wood: put some fine sawdust against your skin under a bandaid. You should know in a few hours or less if you have to be even more careful around that wood. But if you already suspect sensitivity, a good respirator might be a help - I really like the 3M models fitted with dual P100 filters.
I got a bad dry cough when my doc put me on lisinopril for bp. The cough went away in a day after switching to another med.
Wouldn't hurt to give your doc a call.
Any wood is an irritant if you get too much of it, even poplar. As we get older, we get more sensitive to all kinds of irritants that didn't bother us before...
Within days of being put on lisinopryl, I developed a dry, hacking cough that would just not stop. I did a bit of internet research and came across a page that referred to my symptom as "the dreaded lisinopryl cough."
When I mentioned it to my doctor, he said, "Yep. We'll switch you to something else." He did, and the cough was gone in two days.
Still, I take the point of view that ALL wood is allergenic. My Resp-I-Rator air filter system is as much a part of me as my face shield when I'm turning/sanding.
