OT Bottle Jack
OT Bottle Jack
OT Bottle Jack
Dustmaker Mike
All right I have sort of a strange question. I have a 20 ton arbor press that I might want to modify a little bit if I can. I was using it Saturday to press out and in U-joints. As was was pumping the handle about the ten thousandth time I had a brain burp. Why couldn't I add a little Hydraulic pump and switch to automate the handle pumping.
It is just a 20 ton bottle jack stuck in a frame.
Is there such a way or just get a local kid to pump it for you :\
Re: OT Bottle Jack
Re: OT Bottle Jack
Tom Dunlap
I googled and found some leads about converting a bottle jack to a hydraulic ram. It seems that a few fittings and a pressure regulator will be needed.
Tom
Re: OT Bottle Jack
Re: OT Bottle Jack
Dustmaker Mike
Thanks I did a little googling and found some stuff on how to do it. Now will it be worth it in the end?
Thanks
Re: OT Bottle Jack
Air operated jack?
Northern Tool sells an air-operated hydraulic jack:
http://www.northerntool.com/shop/tools/product_200641739_200641739
I have a 20-ton press I use quite a bit on the farm. I am considering modifying it to use this. It would be a WHOLE lot easier and quicker for repeated operations than pumping the lever. I think the pneumatic control would be less hassle than and take up less space than adding high pressure oil lines, electric pump, and control valve, even though my press already uses an external manual pump connected by a flexible hydraulic line.
Re: OT Bottle Jack
Wow that would work great
Dustmaker Mike
I have the air source right next to it.
Thanks
I will have to look at it a little more now.
