Re: Drawer Bottom Engineering
TomD
You probably don't want to glue them in and it is unnecessary anyway. If your sides are real wood then you are just asking for trouble if you use glue as there will be some wood movement even though the drawer is essentially a frame and panel.
1) you want to determine whether you are really concerned with strength or panel stiffness in this app. The stiffness tests are different, and more likely your actual concern. Stiffness is easily measured by deflection over a span. So with something like joists, the engineering data may tell you what span will create a 1-480, 1-360, or 1-240 deflection for a given static load. as the panels deflect in your drawer they start to load the edges of the grooves unevenly promoting failure in that region. So a panel that can stay pretty flat is advantageous. This would seem to be pretty easy to model.
2) Plywoods tend to be available in two quite different types. One, typical of better furniture, boat and aircraft panels will be almost as stiff in the 0 as 90 fiber orientation. Typically these will have many layers of thin plys. Or at the cheaper end, as with underlayment, a thick core, with very thin face veneers. These panels will function best in nearly square drawer bottoms, but one must still be careful to align the fiber with the shortest span
The other type is the often 3 ply material where each ply is the same thickness and therefore the ply is dramatically stiffer in usually the 0 axis. How you orient and contain these plies is critical to performance. Since stiffness varies as to the cube of thickness, relatively minor looking changes in plies can completely change a panel's characteristics. For instance, out of the blue, the underlayment we get is now stiffer in the 90 and not the 0 axis.
Of course this thinking applies to solid wood bottoms also, they are linear fibers with the vast majority of their stiffness in the 0 axis, this can be very powerful in some drawer applications
3) how you engineer the opening is also critical. If you had a drawer that was 48 inches wide and 12 inches deep and you cut the ply so that the 0 axis was front to back in the drawer, but the back of the drawer was open with maybe only a few tacks, that would be a very limp drawer bottom. But the same drawer containing the ply on all 4 sides would be very stiff since the 0 axis is supported over the shortest span (front to back).
