200+ woodworking book reviews
coolant?
coolant?
coolant?
Mike Van Pelt
what anti freeze brand do you recomend for Legacy Explorer water cooled motor?
thanks
Mike
Re: coolant?
Re: coolant?
Mark Nowicki
The brand that the dealer sells.
Re: coolant?
Re: coolant?
John McGaw
Hey, I can't even figure out what a 'Legacy Explorer' is. Some sort of Subaru or Ford or what? But the real answer is that you must use the type/grade of coolant called for in the owner's manual; this will take into account the composition of the engine and cooling system components.
Re: coolant?
Re: coolant?
Mike Van Pelt
CNC Router......sorry not an automobile!
Re: coolant?
Re: coolant?
Chuck in Mtl.
Prestone is a good brand although Evans waterless coolant is a better choice.
Re: coolant?
Specialized application - call Legacy
Re: coolant?
Re: coolant?
John in NM
You might want to look for some anti-microbial glycol, we found it necessary in an equipment chiller we ran one place I worked. Thing ran right around 74 F and it grew crud like crazy.
The one we run where I work now uses industrial propylene glycol - which is pretty benign stuff compared to ethylene glycol. It probably has microbial inhibitors, but I've not checked.
I would recommend propylene glycol if nothing else, less hassle if spilled or if you flush the system out now and then it's more easily disposed of.
I believe Sierra brand auto antifreeze is propylene glycol if you can't find an industrial source locally. Auto antifreeze will probably grow slime though, so I'd still look for some of the stuff designed to run at the temps you'll be running it at rather than 240 F or whatever cars run at these days.
