Drying crotch wood
Drying crotch wood
Drying crotch wood
Craig Spacek
I just stumbled on what I think was a pecan tree that had been cut down and was able to grab a bit of wood before it was hauled off. It is a crotch that I cut into 4/4 slabs about 24"x15". I found some really nice figured grain in the slabs and am unsure of how to minimize loss. Currently I have it stickered with Anchorseal on the endgrain. Would it be less likely to split and check if cut into veneers while wet or should I leave the slabs thick to dry? Is crotch wood stable enough when dry to use in solid board form or should it be veneered? I wasn't expecting this hunk of wood so I didn't get a chance to research the drying at all.
Thanks for any help,
Craig
Re: Drying crotch wood
Craig, I don't know about using pecan/hickory crotch for boards or veneer, but for crotch chunks of most hardwoods for woodturning I anchorseal the ends, about an inch down the sides, AND the entire exposed wood face of the crotch. This helps but is not insurance.
I've dried crotches of black cherry, maple, sassafras, elm, walnut, and others and maybe they are more forgiving and rarely split BUT since I always seal a crotch face I don't know how they behave unsealed. Btw, rather than leave the wood in the half round I always saw a crotch into a slab or block - maybe this helps. (For wood that warps and splits like crazy close to the pith such as flowering dogwood and persimmon I would probably give up before I even tried to save a crotch! I tried several times and failed miserably.)
Pecan T/R ratio is reportedly close to tulip poplar which is usually well behaved. What hickory I've sawn (sorry, no crotches) was pretty stable. I air dried a bunch of 4x4 and smaller hickory and it didn't warp much at all. As for air drying thin boards in general, I use a lot of stickers and wedge-clamp the whole stack to thicker boards top and bottom.
Put some weight on it.
Three concrete blocks (6" solids) stickered above the wood surface should do. Shuffle the stake once a week for a month or two, the fahgedabowdit 'til next year. ;)
looking ahead to veneer
When it comes time to slice veneer you will need to flatten one side. After sawing the first slice the tension in the rest will likely leave the face no longer flat. You could loose a lot of veneer flattening, sawing, flattening, sawing etc.
Solution- When it comes time to slice the veneer fist glue something thick and stable to one side to hold the crotch wood in place as it is sliced.
I have only dried one crotch and I sealed all surfaced to slow the drying. It still split on the top of the crotch.
TomSontag - St. Louis
As others have said, you should coat the figured part of the crotch face too. It is essentially end grain too. Expect flaws and checks anyway, but drying slowly is best.
