Stairs:Fastening treads to stringers
Dave in Bryn Mawr PA
Would like to do this without drilling holes in the treads. Access underneath is very limited. Any recommendations?
Re: Stairs:Fastening treads to stringers
Dick Coers
Construction adhesive is about the only thing I can think of that meets your criteria. Never heard of that being the only fastening system though.
Joseph Mulherin
Dave, do you happen to own a PIN nailer? If so, I would use the construction adhesive and 2" pin nails.
TomD
The fast way would be biscuits they often are tight enough to not require clamping, but standing on a tread for a few minutes either way should work.
If you want a lot of fastener, and damn the deconstruction, epoxy hardware bonding would work, but it is slowish for a bunch of treads. However you can probably hang a truck from each tread when you are done, assuming you stringers would hold.
John McGaw
I take it that you are talking replacing existing treads with new ones? Or are you talking about putting new treads over existing treads to improve their looks? For new construction the obvious choice would be taper-grooved stringers along with wedges and glue.
In preference to other, adhesive-based, suggestions, you could always choose to 'celebrate' the attachments by drilling and countersinking screw holes and plugging with matching or contrasting wood. I've seen beautiful stairs that had new QS oak treads and contrasting walnut plugs over the screws. Of course you could always make your own cross-grain plugs from carefully chosen wood (trimmings from treads which are often too long?) and install those for a nearly-invisible coverup.
C. John Hebert
It won't last with construction adhesive
Re: Stairs:Fastening treads to stringers *LINK*
Grant in Iowa
Dave,
More information (maybe a picture or drawing?) of your situation would help us provide realistic options for you. I am not sure if you mean stair tread as in piece of lumber, or if you mean tread as in vinyl overlay or similar.
In the mean time, assuming you meant wooden stair tread, I think you could likely use stair tread hardware style "hangers" that are available in the joist hanger area of your hardware store. Depending on your situation, you could fasten them to the stringers, then apply your treads. If you can get a socket wrench beneath the treads, you can then drive lags in to the (marked and pre drilled) treads with limited space. If there is no access beneath, then assemble the stair with stringers before installing it as an assembly. Again, more information is in order here.
You need some type of hardware or rabbet, or in some way a method of mechanically attaching the treads to the stringers to be safe. Construction adhesive alone is not a great option. Ask yourself if you would bet your grandmothers hip on whatever you come up with.
Regards,
Grant in Iowa
stair tread hanger hardware
OT: does this mean
Bruce, a MN Galoot
You're back?
trim head screws or big finishing nails and construction adhesive is the typical method. The tiny hole will not be noticed by anyone but you and your concern will evaporate with time.
clay foster
This is the technique I used for a remodel in our bedroom. The treads are old growth yellow pine salvaged from timbers in a cotton gin in Arkansas. The plugs are black walnut.
