Look for...
Grant in Iowa
Tom,
I made side money by repairing snowblowers and mowers for a few years. Modern big box units are not typically built to last. Look for these features:
-a CAST IRON auger drive gearbox. The die cast zinc models don't have the rigidity to hold up long term. This is the gear case seen located between the snow auger and the shaft from the drive system. Ariens still makes some models that have this feature, along with some other premium brands such as Toro.
-a differential drive system so you can turn corners without fighting with it.
-Warranted chute systems. Toro offers this as well as Ariens.
If buying new, you'll be around $1200 or so before you start to see these features. A lesser machine might last for you, but a machine with those features is better equipped to last long term.
If buying used, just find a pre 2000 or so Ariens with electric (extension cord) start, and the cast iron drive gearbox with as little play as possible (turn the auger by hand back and forth to see how much play there is). You can fix everything else, but that gearbox and the shafts are pricey to replace. Be an early bird shopper on craigslist starting now to see if you can find one. And while you are at it, find one with the tall skinny tires. Much better traction than the small tires on them today.
FWIW,
Grant in Iowa<-upgraded to a Kubota BX 2200 with a loader bucket and a 48" blower on the rear. Don't like the snow in the front yard? Just blow it to the rear!
