cabinet redo
cabinet redo
cabinet redo
Gary Smyth
I’ve had this cabinet (68 x 18 x 11) for a while and the weather has broken slightly cooler. I’d like to return this into what once was used as an old fashioned medical cabinet (without glass). Searching the net I’ve found several examples of similar look. This cabinet is not metal and needs some repair on its sides. Originally of ¼ plywood, the bottom was in a flood and the plywood cracked and separated. The doors are solid wood and fine but need to be stripped, then repainted. I plan to reskin the sides with 1/8 wood and then, with a completely new base, top, casters, graphics and white or (as a twist) military olive drab paint put it into service. Several questions.
1. When reskinning, what glue is better for this application –contact cement or wood glue? The cabinet is 68” tall and reskinning the whole length without some sort of pressure is of concern. Cauls will work if I can figure how to exert equal downward force. I do not have access to vacuum.
2. Is there any way other than stripper and elbow grease to clean up the inside? Maybe use additional 1/8” and reskin there also? The shelves are (so far) permanently attached and access with scraping tools is difficult. There are traces of white and yellow, along with the red paint, I’ll never get it all and probably lead so I plan to repaint the interior if I can clean up what is there.
3. Would spray rattle cans work on this?
If anyone has seen pictured medical cabinets similar please get me a link.
I’d like to get this finished in the next two weeks and on to other projects.
similar
Re: cabinet redo
Re: cabinet redo
John in NM
One thing you can try for re-skinning adhesive is white glue (as in EVA instead of PVA). You paint it on both sides, let it dry, and then iron it on. I did it once with Tightbond III, which is when someone here on the forum told me about EVA working better. EVA glues are a bit hard to find these days since they are not as water resistant as PVAs. One brand I know of is Weldbond.
For paint strippers, best stuff I've used is the MeK jelly. Next in line is the orange jelly or a heat gun.... heat works better but is more time/trouble than a chemical stripper. If the paint has lead, the best thing to do is use either heat or chemicals to soften it and scrape it off. Dust is what you want to avoid with lead paints (AFAIK). If you strip the surfaces, you will want to sand briefly afterwards, that would be the time for a dust mask if you are concerned about lead. Reskinning over the paint might work ok if you are using contact adhesive, but I would not expect it to last well.
Re: cabinet redo
Were It Me
I'd take the whole item to a strip joint where they can use the immersion method to do inside and out together. Tough on the wood but you get back a "base" from which to start without having to screw with the chemicals and disposal of same.
Re: cabinet redo
Re: cabinet redo
walta
I think skinning the side will make more problems than it solves.
How will you cover the edges?
Will you do both sides so they match?
Please post a few close up photos of the damage and how the sides attach to the front.
When I see plywood I know the item is not older than me there for it can not be an antique :)
Walta
Re: cabinet redo
Yikes, how old ARE you?
From the ultimate authority, Wikipedia :-) :
"Plywood was introduced into the United States in 1865 and industrial production started shortly after."
Re: cabinet redo
Sorry,  away for strip estimate
