For the second time in my 20 year woodworking career I find myself sawing a log into boards, but I seem to have forgotten some of the basics. I intend to air dry because I like the look of the grain better than kiln-dried. But I can't remember the drying times for the various parts of the process. After I paint the ends of the log to minimize checking, how long should I wait before sawing it up into boards, or, should I say flitches? Also, this is a cedar log that I want ultimately to cut into 1/4" or 3/8" boards to line a closet or cabinet. Should I cut the flitches to that thickness from the log, or should I cut thicker flitches and then cut them down to final thickness after full drying?
Letting the log sit around will only permit cracking and bug infestation. I would saw it at least 1" thick stock, and resaw latter. Sawing to 1/4" or 3/8" green will likely produce a lot of warped and twisted stock. Air dried is fine, but there is always the danger of powder post beetle infestation. I threw away some quarter sawn sycamore just the other day. You have to get the wood over 135 degrees to kill the bugs.
I would saw immediately. The drying doesn't start until the log is sawed but the end checks do.
ERC dries quickly - I haven't timed it but just check with a moisture meter. If I am in a hurry, I sometimes lay the boards out flat on one of my big trailers in the air and sun. If full sun, I flip them over in a couple of hours then a couple of times a day until dry. I've had only minor very warpage with 1"-2" thick boards. It is safer to sticker them with weights and let dry a little longer. ERC is the fastest drying and most stable wood I have ever put through my sawmill.
For 1/4-3/8" final thickness I would probably cut and dry in slabs 1-1/2 to 2-1/2" thick then trim into boards and resaw. Thicker would take longer to dry of course. Sorry, I don't know drying times for thicker slabs since I usually keep them around a few years before I use them.
This makes me want to fire up my Woodmizer! I have about 15 cedar logs waiting on my pile.
As I recall, the 1"/year is for hardwoods. About 20 years back, I needed some 2" thick slabs and went to a local sawmill. I was amazed that there were 2 within 20 miles from my home in CT. They custom cut what I needed and told me to let the wood sit for 6 weeks. I believe that it was some kind of evergreen.
wash the boards off with chlorine bleach and water (to kill any fungus), seal the ends again plus an inch or two in, surface dry them flipping them every 4 hours.
Lastly, if you want flat boards, stack and sicker them with 3/4" between them on a flat base or floor protected from rain (tarp/roof, etc.)
Me...I'd wait 6 weeks and no paint on the ends. I've sawed a lot of eastern red cedar and that's what I've done. The sap dries out pretty fast and I'd rather saw a some what dry cedar log than a fresh cut one.
Very interesting, Basil. You seem to be in the minority; I'd like to explore your thinking a bit more. Are you saying that the wood is so oily that no sealing is necessary? I may be showing my ignorance here. What I have is what I would call aromatic cedar; it's the stuff used in closet and cabinet linings, as well as sachets (I'll try to catch my planer shavings and sawdust for that). Sorry if I didn't make that clear in my original post; I know I just said cedar. I don't know if that's the same as eastern red cedar. I know it is NOT the same as western red cedar.
I have already sealed the ends of the logs with a 1:1 mixture of Titebond Original and water, but haven't started sawing into flitches; today was a rainy day and the glue is taking forever to dry. Do you think I should cut it into thick flitches after 6 weeks and wait a year to cut the thin boards, or just go ahead and cut the thin boards after 6 weeks?
ERC doesn't seem the least oily. From my experience it probably doesn't matter much whether you seal it or not. Unlike many woods, although it will check if unsealed it won't firm deep, board-wasting splits. I say "won't" but that's just my personal experience. For example, I currently have some fairly large (14-18") ERC logs that have been sitting in the morning sun unsealed for about 3 years now. The ends are checked but the checks are not deep when trimmed.
I don't think the 1" per year drying time applies to ERC. Just my experience. I do let large turning blanks and 2-3" slabs dry for some time, usually standing vertically out of the weather after stickering for a few months - I've never had one to warp, even some almost 24" wide. It is probably the easiest wood I've ever dried, besides Dawn Redwood.
I personally have not noticed any difference sawing ERC immediately or after a year. It doesn't gum up the band with resin like virginia (scrub) pine, at least the cedar I get around here. Saws easily, even when logs are very wide. My favorite wood to saw.
I usually cut 1" rough boards for siding and such but I also usually cut some much thicker (4-8") for turning blanks, especially when I get some with a lot of figure and with an interesting mix of red and white. Some pics below, just for fun! The 2" slabs make fantastic platters (sorry, no platter pictures).
It sounds like you're interested in closet liner stock, which is typically about 3/8" thick when you buy it in cartons at the bog box store. It also sounds like you're anxious to get on with this, so here are a couple thoughts...
Someone mentioned cutting the wood into fairly thick billets. I agree. I don't recall what kind of mill you're using to cut your logs, but I wouldn't want to try to saw accurately to 1/2" or less thickness with a band mill. A little bit of blade wander and the board is ruined. With a billet, say 2" x 6", you can flatten and edge joint it, then resaw it quite accurately on a bandsaw, say just 1/8" over final thickness. If you joint the billet after each pass on the resaw, you'll have one dressed side on each board. Sticker them carefully and let air circulate around them for a couple weeks and you're probably good to go.
