Ripping iep
Ripping iep
Ripping iep
Dave in Bryn Mawr PA
Making porch stairs using pie. I know it's very hard and am thinking of using my 11/2 hp table saw with a thin kerf blade. Any advice on this?
Re: Ripping iep
Re: Ripping pie
Lee Schierer in McKean, PA
I prefer apple pie or cherry pie, but I've never used them for steps.
Hopefully you mean Ipe. Use a carbide tooth blade and you should be fine.
Lee
Re: Ripping iep
Blade
Put a 7-1/2" carbide blade on your saw
Make sure you fence is set slightly open (.002" when locked) at the back
Use push sticks and feed the wood smoothly without stopping
Re: Ripping iep
One wrinkle...
John in NM
I would be sure to use a blade with a moderate hook angle (less than 5 deg) rather than any old framer's blade with a 20 deg hook. Large hook angle makes for an aggressive blade. When you get into small blades you have to watch for that as they have many more applications than 10" blades.
I've never tried one of those on a table saw, but did once make two cuts on a friend's RAS that had a skilsaw blade on it. Two cuts was all I needed to learn the lesson :D
Re: Ripping iep
best advice, don't get any splinters
Dick Coers
My body doesn't react well to ipe. A splinter will be festered in a couple hours for me. I like the Freud 10", 24 tooth rip blades. I break the sharp edges with a router.
Re: Ripping iep
Not exactly the same application.
Keith Newton
One should never use over about 10* hook angle on a RAS, because it is climb cutting, and can get too much traction, then overpower the operator.
On the TS, more hook is usually desirable for ripping. Unless, the finer sharpness angle which comes with the wider hook is too fragile for this hard a wood, causing it to dull too rapidly.
In which case, I've been running a thin kerf Frued 7.25" demolition blade on MDF and liking it for that purpose. I got sold on this little blade while doing the demolition part of the cabin I rebuilt next to mine for my cousin. I don't know how many nails I cut through with it, but one was a 20d common, end to end. When I finished that cut, I thought that blade would have been trashed, but it still looked new.
Later, I cut through about 200' of roof deck with two layers of composition shingles on top, and it still got to stay on the saw.
Re: Ripping iep
True...
John in NM
And that is something I acknowledge when pointing out that I've not tried a framing type blade on a table saw. Even if it works well, that aggressive hook is something to be approached with caution, and the implications are not necessarily clear to everyone. I am pointing out those implications.
