fierglass tub chip
james runchey
I have a small, 1/4 inch diameter chip in a fiberglass tub, right in the bottom on the curve. What is the easiest repair?
fierglass tub chip
james runchey
Re: fierglass tub chip
George Koch
A professional recommended by your local plumbing supply store
Joseph Mulherin
I would recommend them 5minute epoxy kit at HD
Lowe's and Home Depot and plumbing supply houses Probably all have repair kits. White should be easy. You mix up the little batch and put it in the divot and press it into place with a little sheet of cellophane that come with the kit, that gives you the slick finish.
Actually, I like the idea of hiring a pro. you did ask for easiest. You should seal the hole, it might leak.
fredhargis
What George said, call a pro.
Grant in Iowa
We had a chip in our master bath shower, thanks to clumsy electricians during the building of our home.
Since the shower was built in place and the sheetrock was already finished, they paid for a repair by a pro. I watched some of the process, and can therefore say you should probably have a pro do the repair. And that is coming from a fierce do it your selfer--someone who never hired anyone to do any repairs until I was 40.
A white shower seems simple, but matching the color precisely is an art form. There are many shades of white. Add to that their commercial chemicals are like nothing available at Homely Depot or Lowe's. Our repair involved a chip in a smooth area, and one on the tub bottom where the textured surface is. Both were completed to where even my critical eye couldn't see it, and the cost was under $200, even though the lady had to re-texture the entire bottom of the shower so it would match. I am guessing your repair might be a minimum repair and cost less than mine did.
Reiterating, hire a pro. Look for fiberglass bathtub repair in your yeller pages.
FWIW,
Grant in Iowa
