Willow tree infestation ?
mdclor
Here is an email from my son:
The bad news from yesterday is that the Willow has tree boring insect holes around split bark. I don't know if it's normal or okay for the bark on the main branches to split, but I fear it is from the borers.
I found this while pruning - I climbed up in the tree to saw some branches. When I sawed one off, a bunch of ants came panicking out from the branches joint with the trunks bark.
I don't think the ants are the borers. I read one thing that said ants can't/don't eat live tree, they only live in hollows where there is dead wood.
So, I have at least ants and probably a separate borer. I really don't want to lose that tree nor do I want the new ones getting similarly attacked.
What is the best answer?
Does anyone have any suggestions?
Re: Willow tree infestation ?
Ants
Sorry, no personal knowledge of this but thanks for the head's up - I will check my only willow today. I planted it 13 years ago.
>is dead wood.
Last year I found a huge colony of carpenter ants in a hollow of an oak tree that had been at least 60 ft above the ground!
I understand they like damp/decayed wood to get started but are not opposed to chewing out passageways and living quarters in healthy wood as needed. Perhaps an arborist will respond to this thread.
Re: Ants...not as much of a worry
Tom Dunlap
I'm working at a tree related event today so his is a short answer
Ants are really not the concern. Decay is the concern. Ants have some beneficial aspects
More later over the weekend
Tom
don stephan
There's no substitute for a certified arborist looking first hand at the situation if the tree(s) is(are) important
Re: Ants...not as much of a worry  *LINK*
Tom Dunlap
First...identify what sort of ants are there. More than likely not termites. Go to your local or regional land grant college website to get the best information.
Here's a link to the U of Minnesota.
There is research that shows that ants can be beneficial to trees with decay. Their tunnels open up the decay pocket to air so that it dries out. Decay likes moist conditions. Dry or saturated don't allow the decay organisms to grow.
Another benefit is that the ants take their feces to particular galleries to 'compost'. There are some organisms that grow there that kill some of the decay microorganisms. Amazing relationships in Nature, huh?!
In general an ISA Certified Arborist should be able to help. More important though is to find a 'qualified arborist'. Like any profession there are Shake and Bake Pros who take the test but don't know anymore than what was in the study guide. Buyer beware. If you send me an off-line note I might be able to suggest a nearby arborist.
Tom
Carpenter ants
mdclor
Tom, for some reason your email address isn't showing. Greg's zip code is 20151 and I am at mdclor at gmail dot com. Thanks for any additional assistance you can offer.
Keith Newton
MD, I'm curious about the bark splitting, is this in a location experiencing drought?
I'm not an arborist, but have cut plenty of trees inhabited by Carpenter Ants. I have found them in numerous decay resistant species where they have developed some incredible networks of tunnels. Under those conditions, I don't think it causes the tree harm.
However, Willow has 0 resistance to decay, and their tunnels do provide an air path deeper down into the heart of the tree, than would be possible without their excavation.
I'm not sure if they will take a bait poison like the Red Imported Fire Ants, but it might be worth a try.
If that works to kill the colony, I think I would follow up by cleaning up the opening, then filling it with expanding foam to try to stop air entry as well as other insects. Decay has to have air to grow.
Tom Dunlap
Ants are probably third or fourth level issues in tree decay. They don't break through the layers of wood tissue into the layers of tissue grown after the damage. Remember trees replicate themselves each year layer upon layer from the apical tips all the way down the trunk
Trying to seal up leaks isn't realistic. In the profession we stopped using any wound paint around forty years ago. There are a couple of exceptions mostly when dealing with oak wilt. Cavity filling went out in the 1940's or so
For more I information on this topic read about "CODIT" or even "Shigo compartmenization"
Tom
Dale Lenz
In general:
Dale Lenz
Borers are usually successful of attacking a tree that is not happy/healthy. Having an arborist is a good suggestion. In the mean time, as a professional forester, I always suggested TLC, Tinder Loving Care. Get some well balanced fertilizer, something with three numbers above 0 on the package, N, P & K. Pepper the ground well, half way from the tree's truck to end of the tree's crown, the drip line and that same distance outside the drip line.
It is usually suggested to fertilizer a tree when the grass is not green, but the soil is still somewhat warm. Good timing around here would be Veteran's day and St. Patrick's day. In your case, do it now and later as mentioned above.
Good luck
mdclor
Keith, just the opposite here in NoVA. June experienced record rain for the month and, I'm told, July was wetter than normal. August was fairly dry, but no worse than normal.
Re: In general:
mdclor
Thanks, Dale, I will forward this to my son.
