Hole saw
Hole saw
Hole saw
Brad Bransky
Additionally, who makes the very best hole saws for hardwoods?
Thanks, Brad
Re: Hole saw
If you want to go through quickly, *LINK*
Keith Newton
This should be what you would want to look for. Fewer teeth, with really deep gullets. I have not used this brand, so I can't say for sure if this is the best. However, 20 ~ 25 years ago, I got tired of hearing my old shop partner agonizing over how long it took to do wiring grommets on the office counter and desk tops, occasionally snagging, and ripping up a chunk of laminate, so I brazed some carbide tips onto an old worn out Lenox body, that was very much like this, and it would drill a 2.5" hole through the 1.5" industrial particle board counter tops with plastic laminate in about 10 seconds.
This is kinda pricy, so if you have an old set of bimetal ones that you are unsatisfied with, you can improve their performance greatly by grinding off 2 of every 2, or 4 of every 5, making a new gullet, so the chips have a place to go, then you can drill until they are full, then come up to clear, and back in much less often than the way they are made. Some have variable pitch, but the idea, is to still leave every other tooth with opposite set, to keep clearance for the body.
As for the Bosch cutter shown in the link below, it appears to me that it could have been better if they had given that little bit of spiral a right hand twist, which would have brought the chips out of the cut, rather than sending them back down.
http://www.lowes.com/pd_352092-353-HTC200_1z0wcja__?productId=3354290&pl=1
Re: Hole saw
Re: Hole saw
Lee Schierer in McKean, PA
I find I get better quality holes with Forstner bits rather than hole saws.
Lee
Re: Hole saw
Re: Hole saw
Steve Jenkins
To improve the cutting action of any hold saw first score the wood slightly then us a 3/8" or so brad point bit to drill one or two holes intersecting the scored line. That will clear the sawdust pretty effectively when you use the hole saw.
Re: Hole saw
Re: Hole saw
Steve Jenkins
Pardon the misspellings. Big fingers on mini-iPad
Re: Hole saw
Re: Hole saw
What Lee said.
If I am using a drill press (or hand drill) - I find that I can drill a better, neater hole w/ a Forstner bit.
I have a couple of large hole saws for drilling door blanks, but that's all they are used for. They are DeWalt hole saws and they are pretty good.
Re: Hole saw
Re: Hole saw
What size of hole?
I like Lenox bi-metal for wood where appropriate.
Re: Hole saw
Re: Hole saw
Jay Lombardo
As an electrician for over 40 years I used every brand and size of hole saw out there. I found Lennox to be by far the best for metal and thinner woods. For larger holes, bigger than 1" and thicker materials, countertops, desks, anything thicker than 3/4" believe it or not I had excellent results with a Skill dial saw. It cut a clean hole very quickly. hole saws are not very good on thicker wood materials.
Re: Hole saw
Re: Hole saw
Brad Bransky
Good advice. I went with the Lennox and am very satisfied with its performance.
Thanks to everyone who pitched in.
Thanks,
Brad
