Re: coping saw blades for wooden rings
John in NM
My first take is a lathe, as Barry suggested.
But you can also make very quick rings using nested hole saws if you solve the burning problem. You drill the smaller size and then use it as the pilot for the larger. McFeely's used to sell the arbors to do that, they called them "oops arbors" if I remember correctly.
I've not had hole saws burn significantly, but then I'm not running them through Cocobolo. Maple or oak yes. Low speed, compressed air to clear the gullets and cut.
