200+ woodworking book reviews
Can you get a battery operated tool that plugs in
I'm looking for a new circular saw. I have always been frustrated with corded saws especially when cutting up sheet goods because the cord is always in the way. So it would seem that a battery operated saw would be a good idea. However as you all know years down the road when the batteries die the replacement cost is prohibitive if you even find new batteries. So what I'm wondering is does anyone make a tool (in this case a saw) that operates off a battery but has an adaptor to make it run off corded AC. Yea I know I can probably jury rig old battery case to run through a transformer but don't know if that would actually meet all the specs needed for the tool.
Re: Can you get a battery operated tool that plugs in
You would want to build a DC power supply into the case. Prob need to measure the current draw with the battery under load then design the power supply accordingly.
But this is an interesting idea - I want to make one now! I can ask my electronics genius buddy Joe about his next week. One potential problem is nicad batteries can supply a tremendous amount of current in a short time which might require a fairly large power supply to properly drive the saw. It might be much easier to make a stand-alone power supply that plugs into the wall and run a cord to the saw
I personally have a Dewalt 18v circular saw I have used many places around the farm and for building my shop. It is the first thing I reach for for a variety of things, precisely for the reasons you mentioned plus light weight.
As for batteries, even a Dewalt rep told me it is cheaper to buy a new tool on sale with two batteries and a charger than to buy the batteries alone. This proves to me the batteries are way over priced. I am saturated with drills and reciprocal saws so the last time I bought a cordless side-angle grinder. Wow, what a useful tool for the shop and farm!
I think Sears sold battery operated tools that had an adapter that plugged into the battery slot. Have not seen or heard of it in the last ten years.
I have a battery powered saw made by Porter Cable. I bought a set from Lowe's on some kind of close out. Reciprocating saw, Drill and Circular saw. Two batteries and a charger. They knew it was dead and sold it all to me for $60. Porter cable thought it was the charger. Sent me a new one, Free. It was the batteries. Lowe's gave me two over sized ones that turned out to also be dead. Porter Cable replaced them free. So now I have the whole setup for $60 and some grief. The circ saw is a piece of crap. Under powered. It is very handy such as for cutting a piece of plywood in some remote location, but still under powered. The drill chuck is also crap. The bit falls out regularly. OTOH, I really like the Sawsall clone. I am sure it is not as powerful as my corded version, but it is much better than the other tools in the set.
So, if I were to buy another battery powered circ saw, I woudl want to play with it first. Maybe some of them don't seem so anemic. I hate cords too. Very long experience dragging one around behind me.
I can tell you this about the Dewalt 18v circ saw: when building my shop I notched fourteen 6x6 PT posts by successive slices to inset 2x10 beams, all from the top of a ladder. The saw never faltered. The light weight and power made this tedious job doable. (I also like that the saw stops in a fraction of a second when I release the trigger.)
Besides a lot of 2x construction cuts I have used it to crosscut 4x4s, cut a bunch of red oak siding for the barn and horse shelter, cut hundreds of feet through plywood and OSB, and slice up thick walnut slabs. Worked well in every case.
One thing, the saw did come with a thin kerf carbide blade which I was careful to replace with the same blade. Perhaps a standard kerf blade would be more strain on the motor and battery for thick cuts.
Don't want to side track this post, but this is the kind of info he (and I) need. I KNEW the one I bought was a piece of crap, but bought it on impulse because it was CHEAP. I am really glad to here the Dewalt version is more of a work horse. I really hope your batteries last a long time, in both senses, run time and life time.
The Instant stop feature is interesting. Works well on the saw. On the drill it seems to impact the chuck open. Drill two or three holes and the bit falls out. I have developed the habit of drill, tighten, drill, tighten.
It kills my soul to trash tools because the batteries die.
John lucas
I broke down and bought the corded Dewalt the guys who built my garage had the battery operated 6 1/2"Dewalt and really liked it i got 40 years out of my Crafstman corded and its still running so its hard not to gk with a corded tool The platen is bent and the depth lock doesnt work well anymore or id just keep on using it
Batteries
May the Good Lord bless your stricken soul. I have repaired several nicad battery packs. They typically go bad when tiny crystals or whiskers grow inside and cause an internal short. We have repaired them two ways - one is to zap the pack with a relatively high momentary current from a bank of capacitors or a welding machine. If lucky, this can vaporize all the whiskers and restore a battery pack that is not too far gone, at least mostly. More reliable method is to disassemble the pack and either replace all the cells with new or test and replace those with limited capacity. Often just one or a few cells are bad. This method is more effort since I charge then test each cell separately. I have combined good cells from several bad packs to make one good pack.
It's hard to say if all this is worth it compared to buying new packs. When building my shop I maintained about 10 battery packs I used on maybe 7 Dewalt cordless tools and several lithium ion on another tool. I don't need that many now so I let some that died rest in peace. (I have yet to lose a lithium ion battery.)
