A screwdriver that fits brass slotted screws
If the bit has parallel sides and snugly fits the slot, messing up the slot in a brass screw becomes easy to avoid. It is annoying (and bewildering) that finding a screwdriver to fit brass slotted screws is difficult. I recently needed something to fit a #3 screw for the hardware on the Spice Box. Exasperated, I tried, with surprising success, to make one.
I have many more slotted bits that I ever imagine needing so screwing one up in this exercise was not a concern. Maybe because I didn't care made the job easy. I used the bench grinder with the wheel I use for sharpening, and just started slowly grinding away the bit until it fit the screw slot snugly. I was careful to keep the sides parallel to match the profile of the screw slot.
I mounted the bit in one of the magnetic thingyies that go in a drill to hold screw bits. It works grand. I will not hesitate to grind another should I need a bit of some particular size.
Re: A screwdriver that fits brass slotted screws
An excellent tip. No pun intended.
In my explorations as a Home Inspector and in buying houses at foreclosure I have found hundreds of screw drivers and bits. Crawl spaces are a treasure trove of hand tools. Most empty houses yield a huge (30 yard) dumpster full of stuff, many of them have tools "sets" most of which are missing any bit or screw driver you might need. (Many house also have one of those kits you can get on line or off late night TV about How to Get Rich Buying Foreclosed Homes) The abundance of worn screw drivers lead me to grinding some of them, Based on the premise you can bread something that is already broken.
I like a certain sort of medium sized screw driver as a probe, searching for rot. That lead me to grinding "special" needs ones.
can't remember regrinding one of the tips though. Good Idea. Now if I could just learn to resharpen Phillips bits.
Jim O'Connor
In repairing old furniture especially tables I have found that the screw slots are often very shallow and a little wider than usual so I have also ground and adapted screwdrivers to fit so they wouldn't tend to cam out.
Maybe the old screw manufactures used different specs than today.
Gunsmith tools
If you don't want to grind them yourself (BTW, I do this with the side of the grinding wheel), you can buy a set.
Quality screwdrivers for gunsmiths are ground with parallel tip sides to avoid that very problem of slipping out of the slotted head and scarring the finish. A variety of sizes means you can almost always find one that fits tightly.
A couple of years ago I bought this set of Grace tools which are great:
http://www.amazon.com/Grace-USA--Gunsmithing-Gunsmith-Accessories/dp/B004TABWYU/ref=sr_1_4
Brownells Magna-Set gunsmith bits
BrianMonumentCO
Get a set of brownells magna-set screwdriver bits.
They come in sets of various sizes with different blade widths and thicknesses.
As a gunsmith, I have several sets. Not cheap but good quality.
many of the other sets have a reputation breaking and are of low quality.
Re: Brownells Magna-Set gunsmith bits
Yep, got that set plus another I purchased at Brownells. Son and I collect firearms so need well fitting bits to avoid damage. They do work well when working with brass screws. You can buy extra bits (I did) and grind them when you need a odd thickness and or width.
Re: Gunsmith tools
Dave Bair
The bits also make excellent replacement firing pins for double-barrel and hammer-cock guns. Remove the temper before turning on your lathe; they are a surprisingly close fit and require minimal stock removal if you start with a phillips or square-head bit.
Brownells
I'm happy with the Grace tools so far but I was thinking of getting more. Unfortunately Amazon does not appear to carry the Brownells. Can you suggest a supplier?
Re: Brownells
Rum
Straight from the fountain.
http://www.brownells.com/gunsmith-tools-supplies/general-gunsmith-tools/screwdrivers-sets/magna-tip-sets/magna-tip-super-sets--prod417.aspx
Personally I mostly just buy old stock that have been used to open cans for $0.10 at estate sales and re-grind them.. Certainly lacks the cachet, convenience and generally the quality of a nice set of Grace or Magna Tip drivers though.
The "nice" thing about tapered drivers is that you can get away with having fewer drivers so for a mobile toolbox they are actually sometimes a better choice. The salient point is that you want to have as wide of contact between the driver and the screw as possible, with the hollow ground ones if the driver is to small you only have two points of contact on the ends which actually increased the probability of cam out. The tapered ones will (assuming its close in size) contact across the whole width with a wedging action. The problem with them of course is that they only contact across the top, not across the bottom so a properly fitted hollow grind is indeed better, but a poorly fitted one may not.
I seem to recall reading somewhere that some older slotted screws actually had tapered slots so for those you wanted a matching taper on the driver - but I can't find that again and don't recall seeing any like that (at least none intentionally like that). One thought might be that its apocryphal due to repeated tapered driver action, but if anyone has any evidence for or against that theory I'd be interested to know it (just for the nerd value).
Try   www.Brownells.com
Thanks, gentlemen
I like that 58 bit set.
Any comment on the handle type, #81 vs Hollow vs Law Enforcement?
I prefer 81 & stubby
BrianMonumentCO
Hollow is only good really for your goto bits for deployment/field type exercises.
