outdoor porch ceiling: beadboard??
ronster
I have a new porch about 12'x60' to cover with a ceiling in some way. North central AR in a moist near-river location that gets a lot of fog and dew. My builder is doing this, not me, as I have a full time job keeping me in another State.
Masonry panels like JamesHardy appear to be a no-go in horizontal application due to weight.
Plastics like Azek are too expensive, and have a lot of temperature-driven expansion I'm told.
Vinyl and aluminum seem flimsy to me.
That seems to leave me with traditional T/G planking and wood ply panels. Planks would need pre-painting I think and perhaps painting on both sides (??). The panels would need battens – not the prettiest thing. Other choices or guidance? I'm definitely troubled by this decision hurdle.
Right now I have overhanging trusses on 2' centers. I guess furring those out on 12" centers might be right. I heard someone say a moisture barrier like housewrap is a good idea underneath. The overhead attic is open and well ventilated, so I don't know why I would insulate there.
thanks, ron
Re: outdoor porch ceiling: beadboard??
walta
If the most important thing is no maintenance then vinyl supported ever 12- 16 inches will be the low cost choice. Aluminum is ridged enough to work when supported every 24 inches and is no maintenance but they have a different look and the space will feel different.
The Georgia Pacific ply wood would be fast the web site says “Ideal for porch ceilings” But I could not find the support requirements. Battens are required to cover sloppy installations, I do not think you will find them as a requirement in the instructions.
Traditional pine is not what it used to be some of it rots before the paint fails. Scraping and paining that big a ceiling does not sound like fun.
Walta
Jerry Roberts
I used tongue and V groove 5 in. planking on my outdoor screened in porch abt 5 yrs ago. Its abt 8x20 or so. I painted both sides before. It gets humid in Fl. all the time. It looks good and haven't had a bit of problems yet and don't expect to. I had a bunch of problems before when I had plywood up top.
Ray Thompson
I've had 4 x 8 Hardy panels on the porch ceiling for 10 years and can see no noticeable sag or other problem.
Ray
B&B plywood
I am about as picky as anyone. I used the B&B plywood, painted white before it went up. I think it looks fine. Up on the ceiling it doesn't mold like everything else around here.
Re: B&B plywood
Joseph Mulherin
What is B&B plywood?
Re: B&B plywood
Ron Pemberton
Baltic Birch?
Many years ago (35+) I built a house for a couple and it had a 12 by 24' porch. We put vinyl ceiling/soffit panels up. 12" by 12' each. Fastened on about 2' centers. The first blustery day came along and they fluttered out of there. We reduced the spacing of the battens to 12" OC and they lasted a few weeks longer. Reduced them to 6" OC and used screws with washers to put them back up and they have been there for all those years.
Board and bead (pattern)
Board and bead lumber is the historical stuff to put on porch roofs. The plywood pattern looks essentially the same once up and painted.
Slight side track.....color
A friend of mine just did some work on a really old house. The huge porch ceilings were Haint Blue. Haints being some sort of evil spirits. The theory was that the color kept the evil spirits away. All my life I have "known" porch ceilings are "supposed" to be light blue, sort of sky blue. I have also heard it keeps mosquitoes away by somehow confusing them.
Wonder if the paint charts have Haint Blue?
Don Goodwin
When we had our house built in 1992, the builder used the same 3/8" plywood (4x8 sheets) for the 7' x 65' wrap around front porch ceiling as he used for the soffits and the back screened in porch. All look fine 20+ years later. We have only re-painted once since the original paint job. The joints do not have battens, but were caulked. I just went out and looked and only see 1 joint that has popped a little. I am located in central Indiana, probably not as humid as your area, but it gets there. I am not sure if the plywood was rough-sawn fir or not as it has been too long to remember. I do remember we painted both sides before the builder put it up (we did the painting and electrical to save money).
Much appreciated.  Thank you everyone
Re: I opted for Vinyl about 15 years ago
and have no regrets. I used the standard white soffit, and added extra white nails in the grooves between the edges. Have had no issues in the years following.
Kneale Brownson
You made me look, Barry *LINK*
Kneale Brownson
Guess what? There's info on "haints" and "haint blue".
From Sherwin-Williams
Very timely
Neal in San Jose
I'm in the process of building a house in South Carolina, and will be moving sometime just after the first of the year. I think I'll follow tradition and paint the porch ceiling "haint blue"
Neal in San Jose about to become Neal in Bluffton
I saw that, too.
