REAL MILK PAINT
Anybody know a thing or two about fuel pumps?
My 99 Mazda B3000 Pickup's fuel pump has gotten glitchy. Stopped at HD a couple of weeks ago and it would not start. A friend came and we tried starting fluid. It ran for a few seconds. Had it towed to a shop. There, it started and ran fine. Yesterday it stopped again. A couple of hours later I shook the truck and it started. Then it stopped again. This time shaking the truck did not help. I took a stick and hit the top of the tank next to the fuel pump. It started.
The shop said jostling the tank or pump might get it to run again.
I can't figure what happening. Is it sitting and cooling off? Is it the jostling? is it random? Is the fuel pump going bad? These intermittent things are hard to catch.
The truck starts almost instantly when it starts. I looked up how to replace the fuel pump. They said to start by removing the bed of the truck. WHAT????? The other choice is to put the truck on a rack and dropping the tank out the bottom. Anyway, got any ideas? New fuel pump?
Re: Anybody know a thing or two about fuel pumps?
>removing the bed
FWIW, a friend of mine said it was surprisingly easy to remove a truck bed- just need to remove a few bolts and get help to lift from one other person
I was faced with either dropping the 30 gal diesel tank or removing the bed on my Dodge 2500 to replace a brake line tucked inside the frame. Either would be a mess; the bed has a gooseneck trailer hitch to remove as well. I ended up snaking a new line in from the front.
I can't think of any such shortcut for a fuel pump. I guess I would check the wiring and connectors first. Maybe you can verify whether power is getting to the pump when it won't start.
Dustmaker Mike
The fuel pump is in the top of the tank, so the two ways listed are the least destructive. I have seen guys with the S-10's cut a hole in the bed above the fuel pump. Of course these trucks are in the rust belt and the bed is already trashed.
I would empty the tank and drop the tank.
Re: Anybody know a thing or two about fuel pumps? *LINK*
Lee Schierer in McKean, PA
I did a quick search for "Mazda 3000 fuel pump problem" and found a link where the problem is caused by the inertial safety switch being tripped by the setting and release of the parking brake. There are several other potential causes as well that come up as a result of the search.
Lee
Fuel Pump stops
I was thinking of something like that...
John in NM
While intermittent motors can happen they are pretty rare. A much more common cause of an intermittent condition is a faulty switch. Switches tend to arc a little whenever they are uses and after several years of this the contacts become "sometimes contacts".
That is where I would look - switches and relays. More is the pity that modern cars have a wealth (perhaps an excess) of switches and relays.
Jason Roehl in Lafayette, IN
Yes!
Removing a pickup bed is usually pretty easy. Four to six bolts, plus the tail light connectors. If the bolts are rusty, it's usually pretty easy to get them with a grinder, "blue wrench" (torch) or sawzall. Two fairly strong guys can get a full-size pickup truck bed, so your small Mazda shouldn't be too bad. Just set up some saw horses behind the truck. A little ingenuity, and it can be done solo with an engine hoist, garage ceiling and ropes, and so on.
It's a heckuva lot safer than dealing with draining a 20 gallon gas tank, then messing with rusty gas tank straps, unhooking gas hoses and electrical connections that you can't see, etc...
Jason
I am not a Car Guy......
And I have a lot on my plate at this point. I want to get someone to fix this, but I just don't want to take a whack at it. A fuel pump woudl be $400 or more because of the business of removing the bed or dropping the tank. If a new pump wpoudl reliable fix it, that's fine, but I don't want to spend the money and find out that wasn't the problem.
Also, just having a shop diagnose the problem can get expensive.
Mark Nowicki
Try to find an electrical diagram for your truck.
This one is for 98 Ford Ranger (same as a Mazda)
http://i.imgur.com/heW6nZF.jpg
There is probably nothing wrong with the pump.
Mitchell on Demand does not cost much:
http://www.eautorepair.net/Marketing/html/demo.asp?VID=&Count=Y
This one is free:
http://realfixesrealfast.com/realfixesrealfast.com/Home.html
John McGaw
In my limited experience with such problems, bad/intermittent fuel pump relay and/or loose connections outnumbers bad/intermittent pump by easily 3:1. Great thing about the relay is that it is inexpensive and replacing it takes five minutes. If it proves not to be the problem it can probably be returned but leaving it in place is just good insurance against future problems since the relays are a bit failure-prone anyway.
If you have a good shop....
John in NM
They can figure it out. It sounds like the place you took it is going to play parts bingo - you could do that yourself for less money and irritation.
If you don't want to fix it take it around to several repair shops, eventually you'll find one that is smarter than "no start, replace pump, charge customer"
I may not be giving that place a fair shake, but if they haven't figured out something obvious yet (motors are generally not intermittent failures, switches are), then a red flag goes up. Took me 30 years to learn that, but then I'm only working on stuff like this now and then. A good mechanic should figure that out in just the first few years of his career.
Dick Coers
Can you see a ground wire to the frame? Maybe loosen it up and clean it. Grounding on older vehicles can be an issue. I had an intermittent issue on my first Astro van. Had the pump replaced and that took care of it.
Or........you could buy a new Ford van!
Joseph Mulherin
Barry, before you change out the fuel pump...try changing the fuel filter...it might be plugged is the reason you are not getting enough gas to maintain the running of the engine.
There is a YouTube on a Ranger(which is the same as the Mazda).
Dick Coers
It's been my experience that a bad filter will still let it start, but act funny during acceleration or highway speed. Not saying it's impossible, but that shaking to get it running doesn't indicate fuel filter to me.
The Astro would run with an intermittent fuel pump problem, just didn't want to start. Started thinking it lost prime. No idea if it really did.
Joseph Mulherin
Barry, you are in business to buy and refurbish old houses for resale....right? And doing Home Inspections is a side business....right?
Well, that said....I just want to remind you that THIS is a WOODworking forum.....NOT a
DEAR ABBY....to find out solutions for your business line problems. The Mazda is a tool for you
to do your various works, so take it to a shop and have them repair the problems.
This is clearly an OT post and if anyone is offended, I apologist. OTOH, Wood Central Represents a vast knowledge base and wide ranging experience. Lots of discussions here about truck and vehicles for hauling the wood we use. I use mine for that too. The semi-anonymous nature of of the forum allows people to express things they might be reluctant to say in person. We don't need to discuss Ford verses Chevy, just help each other with the problem.
I come here every day and help whomever I can with what ever their problems might be.
Joseph Mulherin
I apollogize
R. Payne
I had this problem with a ranger, after dropping the tank and replacing the pump myself (for what it's worth and if my memory serves, the fuel pump had a pre-filter or the fuel filter was also in the tank) and not getting the hose from the gas filler opening lined up just right, I replaced the fuel pump relay and that fixed it.
Start with the relay, maybe $10 or $15 and 5 minutes, 10 if you don't know where the relay is located and have to look that up.
ron
Re: Fairly easy to test!
Find the electrical lines that feed power to the fuel pump. Attach a volt meter set to read 12V DC, (may require you to splice in some extra wires to be able to read the meter while you try to start the vehicle), when the truck fails to start ~ If there is 12V reading and it still won't start it is a faulty fuel pump ~ if there is no voltage, then you have an electrical issue, not a bad pump. If it is an electrical problem, then you have the option of replacing the fuel pump relay, (and possibly all the switches in the circuit or obtaining a manual and tracing the electrical issue ~ or taking it to an experienced mechanic and paying the high cost of his training!
Thanks for all the help.....
Tried to study the Owner's Manuel on this. The list said the Fuel Pump Relay was Number 32. Looked into the box under the hood and there was no number 32.
Went to the Auto parts store to get a fuel pump relay. Took two tries. First place did not have one and could not find one in the system. Second place had one and sold it to me for about $17. Neither place had any good explanation of where NO. 32 should go. Turns out there were three identical relays in the box. I pulled all three to check the pin alignment and reinserted them. Finally, I noticed that the diagram in the owner's manual had tiny little numbers beside the pictures of the relays. These numbers matched the chart, but not the ones in the truck. Now, If I understand, the relay they sold me has nothing to do with the fuel pump. I pulled the one for the pump and the contacts looked a little "smoked". I cleaned and reinserted it and the truck starts and runs. I hate these little electrical mysteries. I think I will go back and buy a new relay for the right position.
Thanks again for the help.
JoeW, Detroit
I had a 1985 Ford Escort with the same problem you describe. The fuel pump on that car was located in the engine compartment and was operated by a piston. The piston had worn and was shortened to the point where it would not always work. Changing the pump fixed the problem. I think it was a pretty easy fix.
Kneale Brownson
Pumps can develop intermittent behavior....
Kneale Brownson
What usually happens with the in-tank pumps is two-fold.
First, they rely on the fuel for cooling, so if you routinely run the tank down to near empty, you're reducing some of the cooling, which can shorten pump life.
Second, if the pump is "running out of gas"--getting near its wear limits--it can cause extra draw on the power supply, which can stress the relay that lets the pump run if the computer sees everything else is OK. That relay can start to fail and cause intermittent pump performance.
I have a bunch of Audis, all with in-tank fuel pumps. Audi provides access covers to permit pump replacement without dropping the tank.
Nope...
John in NM
Very rare for a motor to become intermittent. Your number 2 proves my point - the relay, not the pump, as I said.
Most problems motors develop get progressively worse, not intermittent - unless its a capacitor start motor with a switch that can fail in the way relays fail - the contacts. Physical blockage of an inline filter is about the only thing that might produce this fault, and even then I'm skeptical.
Mechanics playing parts bingo often speculate that the windings are cracked and become intermittent upon heating - neglecting to explain how said windings can crack without first melting their insulating shellac.
