sanding Titebond I v II
Jerry Gibbs
Just had some glued up panels sanded at a cabinet shop. The shop used a drum sander with 80 grit. The owner said the paper loaded up with melted glue and had to be cleaned periodically because I used Titebond I and there would have not been this problem with II. I have never heard of this. Any comments welcomed. Jerry
Re: sanding Titebond I v II
BrianMonumentCO
How much glue was there?
How long between the glue was applied prior to sanding?
Jerry Gibbs
There was about 3 joints per panel, each 40+". About 3 days dry time. The shop owner said the dry time didn't make a difference, that I melted and II did not.
something odd here
Titebond II crosslinks and becomes irreversible and unmeltable. Titebond I will indeed melt. That said, where was all this glue? The amount of glue in a proper made joint is so tiny as to not be a sanding issue under any circumstances. The glue in a properly made joint can't even be seen.
AZ in Colorado Springs
Did you scrape away the squeeze out?
I was wondering the same thing. Just how much squeeze out was there?
I have a Perfomax and have never had a problem with any kind of glue IN a edge joint. As Bill points out the joint would be tiny and the sand paper woudl be shearing away the nearly invisible edge of that. (Wonder what the thickness of a properly made joint is? Nearly nothing?)
squeeze out
Jerry Gibbs
Most of the glue was scraped away but there was some visible on the surface. The joints were tight. The operator made it seem like Titebond I was always an issue.
not so
Virtually all the furniture made in the world is glued with some brand of the formulation that Franklin calls Titebond I. Unless the glue is in excess panels most assuredly can be sanded without issue.
