I have installed 3\4 inch red oak floor in my living room and dining area. It has been sanded with 50 grit paper for leveling. I plan to sand it next with 100 grit and then 220 grit. My question is would it be best to put down the wood filler after the 100 grit or after the 220 grit and then sand it twice?
I don't know anything about wood filler but sanding a floor beyond 120 is a waste of time. I don't sand many furniture projects beyond 180. In sanding never skip more than one grit size. If you have sanded with 50 the next grit would be 80, but in fact I would probably do 60 next.
It would seem to me that how fine a grit to use on a floor is to some extent up to the individual rather than a hard and fast rule. The finish to be used may determine to absolute highest grit to use, but the higher the grit used the more detail visible in the wood, in my experience. If one is planning on a highly pigmented finish sanding can stop at a lower grit with no sacrifice. But the homeowner should be empowered to make an informed decision.
What Bill said does hold for floors--don't skip more than one grit, and don't bother going past 120.
Beyond that, if you want to get the floor done, do some online research as to how to refinish wood floors (NOFMA is one of the standards organizations). If you want it to take forever and a day, ask woodworkers...
I've done a fair amount of refinishing floors, and the homeowner jobs done with rental equipment are very easy to spot. It takes a bit of training to learn how to do it efficiently, with the right equipment.
I scraped our living room floor because I knew from being around professional floor finishes that I didn't have the experience to sand it. And I have seen even very good finishers screw up. Stuff goes away at miles per hour with those flooring machines. A moments loss of concentration and the result can be a problem had to fix. I have a wavy ash floor because the best of the local artisans had never done ash before, over did the swirling pad and slightly hollowed the soft grain. . Hence, I scraped the living room floor milled from hand selected white oak lumber. I could only do about 75 sq ft a day but the risk-free result was worth the aggravation.
I agree with everything Bill said. I have sanded several floors, all of them oak. Oak is coarse grained enough that sanding beyond 120 is a waste. (You MIGHT get some benefit on maple, but not on oak)
I tried the U-Sand machine. It worked and was essentially risk free because it was so slow. You sand and you sand and you sand. Still not bad for an amateur after the coarse work is done. Not nearly as physical as a drum sander.
You should use sandpaper like you stole it or bought it with somebody else's money. Dull sand paper will eat the soft grain away faster than the hard grain, leaving the floor rippled.
I tried scraping one. Thought I was going to pull my arms out of the sockets. Clearly need some instruction on that.
I didn't run out of time after 75 feet. I ran out of arms. It is an upper body workout. But a properly sharpened scraper rolls up shavings like a hand plane
I believe you. I tried a card scraper on some spots. You can burn your thumbs if you get carried away. I tried using a hook scraper and a card scraper. Switching back and forth helped.
there is a floor scraper, about 4" wide. The secret is sharpening it. When its tuned it mows off wood almost like a hand plane, but it is hard on the arms.
Floors are not very flat. One would do a lot of planing to get one smooth where as scraping is oblivious to floor contours. One just scrapes the joints level as needed and then the finish goes on.
