Doug Fir for outdoor sauna?
Bob Boswood
My sweetheart dearly loves to soak in a sauna. Cedar is quite expensive up here in interior Alaska. Some years back I aquired a lot of Doug fir from a high school gym that was being remodeled. Its really nice wood and I hate to use it, but it just makes sense. Not sure If I will be able to use it all before I pass from this world. The design I am thinking of is like looks like a whiskey barrel laying on its side with the bottom chopped off. Any advice on the pros and cons of using Doug Fir. I have about 5000 board feet of 5/4 boards 9 inches wide by 18' long. Anyone that may have some ideas on the construction of this type of structure would be greatly appreciated.
Bob in North Pole AK.
Re: Doug Fir for outdoor sauna?
I built a Sauna many years ago. I had to pause for the flashbacks. The ladies loved it.
I think Doug Fir Would do well. It can be a bit splintery but I think you can avoid that.
I'd cut the boards In half (9') and use those to build the barrel. I think six feet might be too short. I think you want room inside to lay down.
Is this indoors or out doors? Got any plans for how to weather proof it? You could build it like a hoop house and have the outside sprayed with urethane foam.
Joseph Mulherin
Barry has a good idea for the length. Start with a good base and floor. I would use a good router and do a shiplap on the barrel boards. Construct the room like the barrel on its side say 9 feet wide and start with a good inside staves board to screw them shiplap boards to....expanding outward at first then enclosing the barrel as you progress. Fold down cots could be made inside for layinng to enjoy the heat, and chair stools for sitting and sweating. Think of the Indian sweat tepees or the Slavic saunas.
Been thinking about this.
Years ago I met a guy that design some experimental houses. One was barrel shaped, laying on its side. It was big enough to be two stories inside and supported on poles. The "belly" that was below the first floor served as a crawl space and had storage and ducts etc. Another version had a flat floor with arches leaning in to a point at the top. Sort of an A frame with curved bulging sides.
Roofing them was a problem. The barrel started out flat on top and rolled around to very steep. The A frame version started with a fairly sharp ridge making the peak part of the roofing easy, but both of them rolled in past ninety degrees or past vertical. The problem being that the shingles would not lay onto the preceding course and would dangle. In early versions they tried stapling the shingles up with stainless steel staples. Later, on the A frame they changed the angles so that the sides never tucked under. On the barrel they put a substantial Drip edge on it where the under tuck started and used siding below.
Since this is a sauna the wood should remain dry and may shrink. If you plan to introduce a lot of steam, you may have to allow for considerable expansion.
How long do you want this to last? You might be able to get an excellent tarp and throw it over and stake it down tightly
TomD
My experience with D-Fir is that it develops black mold almost instantly. There may be some finish for that. Look at the Larry Hahn video on YOutube on house building all the wood he is using is black, which is pretty much what I would expect.
Not necessarily what you are asking about, but I would do it right once. Plywood, and glass cloth. Read a boatbuilding book, or watch a video.
Joseph Mulherin
That's why I suggested using shiplaps....1 1/2" ones. They would lay over them the joints not allowing any moisture to enter. And if some did....it isn't going to harm hardly anything
