Report Mirka Deros
Report Mirka Deros
Report Mirka Deros
Bill's report reminded me to post about a tool I recently purchased. So here goes...
Mirka has fairly new random orbit sanders out called DEROS. There is a 6" but I bought the 5". I'm not a tool engineer, just a user....a lot! But I must say that the design and function of this sander is really great. The big deal is that it is a direct drive motor that operates very smoothly.
It has a paddle switch which reminds me of Dynabrade sanders. The paddle can increase or decrease speed depending on how much you depress it. There is also a variable speed control on the body.
The hose port rotates so a fixed hose will turn as needed. I have this one hooked up to a Festool vacuum. The pad has holes everywhere! While you can use standard hook and loop abrasives, this sander is ideally set up for using mesh abrasives, obviously Abralon is the associated choice.
The sander is small, lightweight and easy to control. I have been using Abralon pads and I am getting remarkable results. The dust extraction is excellent and I have yet to find swirl marks.
So what is the downside? Cost! This sander costs just under $600! But for my situation, I am convinced it will pay for itself.
For the record, I have 3 Festool sanders. They work very well but they are heavy and bulky. I get achy hands and arms after long use. The DEROS with Abralon is so much easier for me to use and I am getting much better results.
I have no affiliation with Mirka but this is a tool I can recommend....that is if you can afford it!
T.
Re: Report Mirka Deros
I have the 5" CEROS...
Christopher Fitch Memphis
and it's a wonderful sander.
I don't really like the Festool ES 125 I have but the Rotex 125 is nice. However, the CEROS is just a wonderful sander and even though I've never used the DEROS, I can't imagine that your sander is not just as nice...if not better because of how they eliminated the need for the power block.
Enjoy it!
