Report on Lee Valley brad point drill bits
Over the years I bought various sizes of brad points as needed, but there was always some task that came up where I lacked the ideal size. I bought a set of foreign made bits and promptly returned them. They were ground so poorly as to be useless. Tempted by a free shipping offer I sprung for the leave your knees weak priced LV set. I had watched them being made on a LV factory tour and that may have added to the free shipping temptation. Yet I still wondered if I had squandered too much money on the set.
A couple of recent builds required a bunch of drilling and in one case blow out on the reverse side of a finished door would have been fatal. I found that the LV bits drilled quickly and the grind lessened the propensity of the drill to bust out of the exit hole. In fact, just holding a block of wood against the exit was typically sufficient to prevent splintering as the bit exited the back side. They performed better than any previous bit I had bought. (I saw a German bit demonstrated at the IWF show that appeared to be exceptional too, but I have no idea where to buy them.)
The LV bits are made from high speed steel, probably M2, a highly abrasion resistant steel, so the pointy points should stay sharp for a while. It is unclear how readily a dulled drill can be sharpened. You won't touch up M2 steel with a file like some brad points. If you expect to do wood working long enough to justify the expense of a set I would recommend buying the set. As you use them you will probably fee better about the cost.
