Cool video *LINK*
Check this out. Might be the next rage for decorating projects. Looks like Osage Orange to me.
https://www.facebook.com/KKflutes/posts/10204679151199174?pnref=story
Cool video *LINK*
Re: Cool video
William Duffield
Almost 800,000 views in three days is pretty impressive. But, think about how many cataracts and retina burns could have been caused by the microwave radiation from the magnetron if all those people had watched it in person. No mention is made of sheilding. Couldn't he use a Tesla coil or a neon sign transformer or even a Taser instead?
Microwaves?
From the picture on the Facebook page it appears thay guy is using the transformer from the microwave oven, not the magnatron (which generates microwaves.) I see no reason to generate microwaves for the wood-burning trick.
The transformer steps up the voltage to about 2000 volts, enough for all kinds of fun things. This is perfectly "safe" (and perfectly lethal.) Any person who does not know exactly the issues and hazards should NOT try this at home.
Discarded microwave ovens are goldmines for parts: microswitches, motors, timers, etc.. My electronics wizard buddy Joe recently rewound a microwave oven transformer for lower voltage and mich higher current. He demonstrated by melting a nail and exploding an aluminum can. Good clean fun! I sent him the link - I'll bet a chunk of cocobolo he will try this before the end of the week.
Re: Microwaves?
John in NM
Correct, that is just a transformer.
Interesting trick the guy has there, though I would stop the process before the final flash myself - I thought it looked better with the lighter network of dendritic burns than the heavy burn left by letting it get to shorting out.
Re: Microwaves?
William Duffield
I guess I'm going to need to raid the dump. There are discarded microwave ovens piled up there all the time. I guess neon sign transformers are a lot rarer than microwave transformers these days. All the important parts cannot have failed at the same time. Sometimes it's just the display, which flashed 00:00 for several years before giving up the ghost.
Having never actually taken one apart, my knowledge of magnetrons (and klystron tubes in the oldest ones) is only theoretical, and very shallow at that. I should have looked closer at the photo. At least, I know what a transformer looks like.
When I saw the still photo, my first impression was that the piece of wood had progressed beyond spalting and the tracks had been made by tree roots.
Re: Microwaves?
As I just posted in "Turning", I am imagining the effect could be artistically directed by several means.
Another I just thought of - direct the discharge with a point electrode moved to different points on the wood.
We used to have a lot of fun playing with a home-built tesla coils, jacob's ladders, and van de graf generators. The latter has very high voltage but minuscule current so it is safe to handle. Joe would get 11" sparks off the tip of his tongue. Great party conversation piece.
Re: Microwaves?
Jim DeLaney, Austintown, Ohio
Saw it done a few years back, using the transformer from a neon sign. Worked pretty neat, too.
Re: Microwaves?
John in NM
I like that idea with a turning - you could use the live center as one point of contact - assuming you didn't let the arc short out of course, that would probably damage the center.
Could use a solid center too I guess.
You can control what it looks like..
Grant in Iowa
I saw a guy doing this at WoodFest in Amana, Ia. about two years ago. He applied the solution with a paint brush. Doing so allowed him to direct the burn marks more or less wherever he painted.
He had several that he had made on display. He was able to create what looked like trees, lightning bolts (no big surprise there), and intricate patterns that looked like tree roots or trees.
He used a neon sign transformer, and had a way to regulate the voltage, I think by controlling input voltage. I don't recall precisely, but a box with a big knob was involved. Reminded me of the dimmers that were used in auditoriums decades ago. I believe it was a rheostat. He used a couple of chemistry lab stands as a way to mount the probes simply and safely. The smell of ozone and the crackling sound was a neat addition to the phenomenon.
He was selling them as wall art, and seemed to have no trouble getting $50 for them.
We talked and he said each wood has its own conductance and therefore burned differently. Also the moisture content in the board was a factor.
Regards,
Grant in Iowa
Re: You can control what it looks like..
>...and had a way to regulate the voltage, I think by controlling input
Probably a variac, a variable transformer used to control AC voltage.
