Blue stain on soft maple
Has anyone been successful bleaching the blue mold stain that plagues soft maple? I have been able to Chlorox bleach mold stain on nonporous surfaces but it did nothing to bleach blue stain on soft maple, to my astonishment.
Re: Blue stain on soft maple
Keith Newton
No, I think the only way, may be to use a stain opposite in color to cancel it out. The tricky part, is if it is zoned, rather than overall, at the margins.
Yonak
Bill, I was pretty certain the stain is not superficial or a mildew and is pretty specific to maple, so I e-mailed a friend of mine here in Georgia about the issue, who is a sawmill operator and the most knowledgeable person I know about domestic wood identification, defects and characteristics. Here is his reply :
"It is not a surface stain from mold or mildew, nor is it fungal. It is an chemical reaction, an enzymatic oxidation of the sugars in the wood at higher temps and high humidity. It can penetrate deeply into the wood, and is permanent. You can also see it happen under your stickers if there is not good air flow when the wood is drying.
Here in Georgia, it can be a real problem. I fight it all the time. The lumber has to be stickered immediately, and it must have a large fan blowing through the stack to quickly remove the evaporating water from between the layers. Otherwise, if there is poor air flow, the humidity builds up between the layers, and the chemical reaction will occur.
Feel free to share this info. If you Google Preventing Gray Stain in Maple, there is some research that has been done."
