Drawer Blade and Runner Width
don stephan
Wondering how others decide in a chest of drawers on the width of front and rear drawer blades ( horizontal elements between drawers) and the width of the drawer runners (mortise and tenoned or otherwise connected to front and rear blades, supporting drawer sides). Often it seems the thickness is 3/4" or perhaps 7/8".
If there is a gap all the way around the drawer front, the entire weight of the drawer and contents is supported by the runners. In addition to being joined to the drawer blades, the runners often are fitted into a dado in the sides of the chest.
The blades then would only have to be stiff enough not to sag over time from the pull of gravity. If the drawer sides are very close to the sides of the chest, the drawers are essentially supported by the dado in the sides of the chest.
The joinery method between the blades and runners probably determines a minimum width for the runners. Otherwise, how do you decide a width for the blades and runners? Do you always use the same widths, regardless of the drawer dimensions and wood used? Do you relate the widths to the drawer dimensions? This is not intended to be a trick question, just an exploration of approaches.
I'm making a cherry chest of drawers and somewhat arbitrarily decided on 3" width for the blades and runners. The blades are connected to the chest sides with sliding dovetails, the runners to the blades with long tenons (so the tenons can be started, then the sliding dovetails pushed home), and the runners housed in 1/8" deep by 3/4" wide dados in the chest sides.
Curious in Cincinnati
Re: Drawer Blade and Runner Width
comments
Wondering how others decide in a chest of drawers on the width of front and rear drawer blades..............what looks best. 3/4 for a smaller chest like the 3/4 sized chest of drawers I have described here, and 7/8 for a larger piece.
If there is a gap all the way around the drawer front, the entire weight of the drawer and contents is supported by the runners........and the drawer blade.
In addition to being joined to the drawer blades, the runners often are fitted into a dado in the sides of the chest.......runners dadoed into sides is a result of how this joinery was executed in 1790 and not done for additional drawer support. That is to say , if the way you are making this piece is easier with the runners dadoed into the sides then that is the thing to do. Otherwise it is unnecessary work. (It was common in Period Furniture to do a shallow dado and just nail the runner to the case side. This construction held up fine for 300 years.
If the drawer sides are very close to the sides of the chest, the drawers are essentially supported by the dado in the sides of the chest. .........Are you aiming to put your lead brick collection in these drawers? If not you are overthinking the need for strength. Check out some antique chest of drawers for what works.
Otherwise, how do you decide a width for the blades and runners? ....... Blades about 2.5", runners about an 1.25. Look inside antiques for what worked.
Do you always use the same widths, regardless of the drawer dimensions and wood used? No, proportion to the size of the case. I am never concerned about the strength of the drawer support. The shear strength of the blade dovetailed into the side exceeds anything that could be put in the drawer, even uranium.
I think you are needlessly worried about strength of the drawer support.
What are you using for bottoms? 3/8" pine makes a nice bottom unless the drawer is to used as a ladder or for storing the lead bricks.
If you get to Shelbyville, KY visit the Antique store there that is in the old school. It has dozens of English chests of drawers with the typical dainty English drawer construction. Visits there inspired me to make less robust drawers than I used to.
