I am lost Hagner Scroll Saw
Dustmaker Mike
Well a few years ago I received a Hagner Scroll Saw. I turned it on one time way back when and have not touched it since. Well my Granddaughters were here a few week s ago, so I decided to let them use the saw to cut out the letters of their name. I used 3/4 inch baltic birch ply (Now I know to big). The blade came loose and this is where my problem started. I can not get the blade to stay put no matter what I do. Is there a Youtube video or some other set of instructions out there to show me what the H... I am doing wrong.
Thanks Mike
Re: I am lost Hagner Scroll Saw
John Veerkamp
Hagners are supposed to be the Rolls Royce of scroll saws. They are still in production. Their web should have the info you need. They do bring a premium price used, even older ones.
Hagner....errr Hegner.... Scroll Saw
Brian Roberts
https://www.advmachinery.com/manuals/H-manual.pdf
del schisler
i have the 18v and use all the time, which end come's loose from the top or the bottom ? shouldn't make a difference , are the top blade holders the same top and bottom ? you use the key to tighen the blade's . i have never had one come loose only break now and than, here is the phone number, they are pro's their and know what they are talking about, Phone 800-727-6553 and here is a pdf copy of the of the manual also look at the holders, they are the one you should be using, good luck go to page 6 for the holders https://www.advmachinery.com/manuals/H-manual.pdf
Thanks I will take a look
Dustmaker Mike
I will take a look tonight when I get home from work. I know it is me doing something wrong.
We where going to cut out the inside of the letters, so I drilled a hole in each one to start the blade. The first set went fine, it was the second set of letters that the blade would not hold anymore in the top holder.
I will have time to play this weekend to see what is going on. Thanks Again
This is the answer
terry quiram
The screw in the blade holder has become elongated. And the threads in the clamp are starting to round over. The previous owner has either over tightened or has used them for a long time. Remove and examine the screw and you will see this is the case. Buy a set of new clamp holders with screws to fix the problem.
When I was scrolling full time I wore out a couple sets a year.
Re: This is the answer
Dustmaker Mike
Thanks I will take a look at them. If I need to replace them is there a lot of chooses and which ones are better and which ones to stay away from.
Thanks
Re: This is the answer *LINK*
terry quiram
Pretty sure all the clamp blocks are the same for all models. You can order here.
Hegner replacement parts
Re: More info
Dustmaker Mike
Thanks Again
I think I see my problem besides me.
