Thread tear out
Thread tear out
Thread tear out
Jim O'Connor
How do you get good threads without chip out when you cut them. I'm using a metal thread box that I used about 40 years ago when I made spinning wheels. I didn't seem to have a problem then. Now I'm trying to make a slate frame of either hickory or oak and have had all kinds of chip out and broken threads. Its not the cutter, it hasn't been used in all the intervening time. I even used a dilute glue solution on the oak but I'm not pleased with the result. Maybe it is related to wood grain but I don't know.
Re: Thread tear out
Re: Thread tear out
I have no hands on experience, but I would think that a ring porous wood would not be ideal. Try maple.
Re: Thread tear out
Re: Thread tear out
Dick Coers
Wood species is the problem. White oak is better than red, but still a problem. Try soaking the part with thin CA glue before cutting the threads, but give it plenty of time to cure. I prefer to not use accelerator to speed the cure. Fruit woods are the best domestic woods for threading.
Re: Thread tear out
Re: Thread tear out
Jim O'Connor
Thanks, I'll try some different woods.
Re: Thread tear out
Re: Thread tear out
John lucas
The type of wood makes a huge difference i also sharpen the v cutter to the best i can from the factory it isnt that sharp grain direction al plays a role ideally if your having problems adjust the cutter to make shallow cut about half depth then reset the cutter for full depth and me a final cut
Re: Thread tear out
Re: Thread tear out
John Veerkamp
Osage orange also threads well. Boxwood is another good domestic one. Hard close grained woods work best.
Re: Thread tear out
coarse threads?
I agree it is probably the type of wood. Are not most spinning wheels made from fine-grained wood like maple or birch? Mine is, as well as most I've seen.
I'm assuming you are cutting coarse threads. ?? I have made a number of threads in walnut for making gavels (picture) and although walnut grain is fairly coarse it is diffuse porous, unlike oak. I didn't treat the wood with anything other than some wax for lube. Finer threads work best with a hard, dense, fine-grained wood. If I needed fine threads in oak or hickory I would use a metal insert if possible.
I did have a problem with tearing the entry hole in walnut when using a tap. It was a little better when I chamfered the hole first. I always hid any surface tearout with the handle design.
(I use commercial tap/die sets)
Re: Thread tear out
Re: Thread tear out
Jim O'Connor
I used maple and birch today with the same problems. I'll try the shallow thread idea next. Overall the hickory threads were the best, birch worst they just peeled completely off the piece.
Re: Thread tear out
Jack Guzman from Maine
lube
When I was researching this awhile back I read somewhere to lube with linseed oil to improve the cutting action. I cut nice threads in maple and walnut.---Jack
Re: Thread tear out
Re: lube
Jim O'Connor
I tried the shallow thread idea but when I tried to cut full depth it just completely broke out. I hadn't thought of the lube but will try it someday.
When my last attempt failed I gave up on the idea of threads and made the slate frame using stretcher bars with all kinds of diagonal spaced adjusting holes.
Lets face it, my patience with experiments is not my long suit.
