Hearing prottection - Say what?
TomD
My little post about the chipper reminded me of something I came across recently that blew my socks off. Been shooting for about 42 years, and woodworking give or take as long depending on the definition.
Over the years I have read various things about hearing protection, one that stands out is that the noise of a 22 and a framing hammer in db is about the same, but the duration for the hammer is less. I also heard it reported that guns often produce noise around the 160 db range. The noise is unbelievable loud at times. And recently there have been reports (just as regards my little part of the world) that folks are loosing hearing from just one bad range partner when shooting under a roof when the other guy had a muzzle brake on some canon. Any who. The point I came across is that db meters often top out at 160 on the reading. over the years a lot of sounds seem to be at that level for dangerous noises, well it turns out the reason is the meters top out, not the noise. Guns are actually in the 200 range, and as we all know that is a logarithmic scale.
My kids are in music classes where the teacher went deaf, and I supply them with ear plugs. In fact I came across the db thing when looking for a meter they could take to events and bail if they were improperly noisy.
Just wondering. Anyone else come across this kind of happy nonsense where the db ranges are underreported because the meters top out, or where there is generally ignorant behaviour relative to noise.
My advice is measure yourself, use both plugs and muffs if required (I normally use muffs only in the shop). Keep your mouth closed, and get pads to fill in around your glasses, or prop the glasses up over the muffs, or use integrated sets, etc...
Re: Hearing prottection - Say what?
Electronic muffs
>...or where there is generally ignorant behaviour relative to noise.
You can see ignorant behavior everywhere, very often in people mowing and trimming trees. I can't believe the number of "professionals" with chippers and chain saws with no hearing protection and no safety glasses. I personally keep dispensers of the foam protectors next to my box-o-safety glasses in my shop by the barn as well as a handy supply in plastic containers on the big mower and bobcat.
I worry about those one-time shotgun blasts, in particular while on varmint patrol here on the farm. A few years ago I bought some very good electronic hearing protection muffs. These not only dampen loud noise instantly but have volume control - I can crank it up and hear things moving in the brush far better than with just my ears.
I use them with power tools in the shop and when constructing things. I bought several muffs so if several of us are working together we can carry on normal conversation until the instant the nail gun fires or the saw or impact driver is switched on.
Chuck Jurvelin
I can't agree more about wearing your hearing protection in ANY situation that could do you harm. I made routed signs and other woodworking years ago without protection. I also shot trap, used a chainsaw, lawnmower, etc. without a second thought about what was happening to my ears. I have been religiously wearing protection for about thirty years, but the damage was already done. I am now wearing my second pair of hearing aids at about $6000 per pair and I still have difficulty hearing certain tones. Please, please, wear the best protection you can get and encourage others to do the same. You will be glad you did !
BrianMonumentCO
Muzzle Brakes on rifles do one thing well.... That is to send the blast gases back and out so they affect the two people near the shooter on either side.
This redirection of the gases helps to a limited degree reduce the felt recoil.
When I started out of gunsmith school, I installed quite a few muzzle brakes.
Now I don't recommend them as I have learned how much fellow shooters and guides don't like them.
There are alternative.
Eye protection and hearing protection are the two most important things you can have with firearms OR woodworking. And to a lesser degree with metal working where eye protection is very important.
Hearing protection helps when turning aluminum.
Re: Electronic muffs
paul grover
Are you using shouting type of muffs?
I am now wearing hearing aids. Friends ask me if it is because of the noise in my workshop. Well, that might be partly to blame. But a significant cause was a single incident. I was outside demolishing a house deck. For some of the demo I used a crowbar and a sledge hammer. I struck the crowbar repeatedly to get it deeper. After a while, the job was finished. I had ringing in my ears. I figured it would go away, like it does after a loud concert.
It took 3 days for the ringing to subside. But after the ringing was gone, I could not hear as well, especially out of my left ear. I was evaluated by an Audiologist and they told me the bad news. The damage was likely permanent. I then became religious about wearing protection. But as years passed, the damage advanced my decline of hearing. So now I wear hearing aids.
The take away, is don't assume hearing damage happens over years of exposure to noise. It can happen in a single incident. So just "cheating" every now and again can be a big mistake.
T.
These:
Howard Leight Impact Sport OD Electric Earmuff
http://www.amazon.com/gp/product/B001T7QJ9O
One very nice thing is the binaural feature from carefully placed stereo microphones. Just like your unaided hearing, you can pinpoint the direction of the source of the amplified sound.
Dick Coers
"Are you using shouting type of muffs?"
No one else sees the humor here? Or was that pun intended? Must be what Scott Phillips wears since he yells on TV when he puts his muffs on!
Conduction
Tom Dunlap
I'm an arborist, have been for about 40 years. In my youth I didn't wear hearing protection...always wore eye pro. I was only partially invincible.
Seeing so many arbos without basic PPE...eye, ear, head pro bothers me too.
At a safety presentation the speaker talked about how much potential damage can come from sound conduction through our bones. I don't recall the percentage of auditory damage comes through the ear canal and how much is conducted through bone but it was attention-getting.
It would be a real challenge to come up with a way to dampen those vibrations. I wonder how it might work if sound proof foam was made into a helmet?
Tom
All this talk has made me realize...
Stuart Hough
that I did a good thing by putting a box of the foam insert ear plugs on top of the table saw and on the shelf of the workbench. Eye protection is sitting on the
table saw fence near the handle, and on the workbench. When I did the morticing for the workbench top i noticed I started to get a headache, and rightly identified the culprit as the sound from the mallet hitting the chisel. Took 2 aspirin, and put the foam plugs in and finished the last two mortices with no pain, and no ringing in the ears afterward. Now I'm religious about using PPE. Just my $0.02
paul grover
I apologize, I meant to say (Shooting) muffs.Paul.
Joseph Mulherin
Mine showed up after having an MRI at the Veteran's hospital in Loma Linda, CA. 30+ minutes with that drumming right in my ears. The atte3ndent said "it would clear up" yea...now I ,too wear hearing aids.
Also, a lot of was probably caused by my construction days of 35yrs....and no muffs to wear.
Re: All this talk has made me realize...
>...box of the foam insert ear plugs on top of the table saw...
I like the foam inserts for long noisy sessions (bobcat, mowing, etc) but in the shop I discovered I resented the time it took to put them in just to make a quick cut.
For me, the muffs are better in the shop since I can slip them on in a couple of seconds. I like the bright yellow lightweight shooters muffs at the saws since they are easy to spot if I lay them down somewhere.
