Fixing a door question?
I have bought another house to flip. I may have really stepped in it this time. I have discovered that in addition to all the usual stuff the main beam and floor joists are rotting. (Did not see that coming. the house is on top of a hill and I woudl not have expected a wet crawl space. the hits just keep on coming.)
So, I am trying to be economical in my other repairs. There are two bedroom doors that are the old flush doors with luan skins on them that have holes in them. Home Depot has Door Skins. Has anyone tried to replace the skin on a door? Would that be easier than replacing the door? Faster? I am concerned about getting pushed into replacing all the doors?
Re: Fixing a door question?
Kneale Brownson
Kneale Brownson
I have patched holes in luan-skinned interior doors using metal screen and drywall mud.
Time vs cost. The last Luan doors I purchased at Menards for a Grandson that needed a couple to install in missing door areas were on sale for $15 each! Shouldn't take more than a half to one hour to replace the damaged doors. Doubt you can "repair" a damaged door for either that cost or labor time.
Last damaged door I replaced in my old house was the entry to a bathroom. The door is non-standard (about 3" shorter and 1" or so narrower). While searching the damaged doors at the Borgs, I found a $200+ damaged Oak paneled door for (as I recall) about $30. The damage was to the veneer on the top of the door, after cutting the door to size, I glued a new Oak veneer strip to the hinge side and had to insert a piece of veneer (taken from the cutoff scrap) about 1/4" X 1/2" long. This made an invisible repair, total time spent was about 4 hours including spraying the door with poly.
Mark Nowicki
Replace all the doors, preferably with the raised panel look, so some Joe thinks he is moving up in life when he buys the house.
Even in Canada doors like that sell for about CDN$ 40.
N.B. A house flipper should not be wasting his time on a forum.
TomD
The door on my shop turns out to be an interior luan door. What with snow and all that the bottom panels rotted. I got the rotted section cut off, and I ground the edge to a scarf, and then scarfed another piece in there. The saving grace was that the timber framing it was not affected. Luan rots pretty easily, but the pine or whatever was nice. That was all real fast, whether economical in your situation, I don't know, depends on how fast you hang new doors and how much time and money it costs you to get them to a jobsite. Also, you need to want to paint the doors, because the joint is nice, but no normal door has one.
To ensure I didn't suffer a repeat, I glassed the lower section of the door, and it took a while to get that detailed up a to a marine standard, presumably not something you have to concern yourself with.
I have a lot of experience pushing luan to the limit, so a repair like that is like driving a 16 penny for me.
