got the VSC fence a few days ago
ronster
Just got it, so just an initial report. I have been using the Bies on a new model unisaw until now. I bought the VSC tfence with a 42" extrusion. The fence is well made (USA) and designed. Setup and alignment is easy. The extrusion is quite straight (ships from another source). Excellent support from VSC as I had questions about whether the fence pointer would work with the measurement tape already on my saw.
This fence is less clunky than the Bies but not remarkably lighter. I haven't had occasion to use the extrusion's mounting opportunities yet (which might be quite nice). The fence is firm in use. It rides about ⅛" above the table – probably an advantage for 99% of what we do. As you align/calibrate it, you find that it locks in very firmly.
Negatives: no left side indicator for cuts left of the blade, but I don't see a reason why one cannot be added. The right side pointer/indicator centers about 5.25" right of the cutting side of the fence, and has more than 1" of total adjustment range. That didn't work for my saw, but I believe both tapes on my saw were laid wrong by Delta, because from the beginning (of getting the unisaw) I was barely able to set my right side Bies pointer, and the left side couldn't be set. This week I've corrected both sides by pulling and replacing the tapes. Now I can use either fence. The extrusion has some semisharp edges that might try to cut you if you don't ease the corners.
This fence is pricey. I like it and will be storing my Bies.
