CA Glue solvent
John Veerkamp
Are there any less toxic solvents for CA glue than Acetone?
Thanks,
John
CA Glue solvent
John Veerkamp
Thanks,
John
Re: CA Glue solvent
Howard Acheson
Google "acetone, toxic". Acetone is a very common chemical in nature and is found in many products.
Re: CA Glue solvent
Hank Knight
Acetone may be the least toxic effective solvent for super glue.
Re: CA Glue solvent
William Duffield
Acetone is a lot less toxic than a lot of other chemicals you probably have in your shop, garage, and under the sink in your kitchen. You still need to treat it with respect, but flammability is probably a more immediate concern.
Toxic?
What is the source of the prevailing Chemophobia?
Why do you think acetone is toxic? And you are happy to use the cyanoacrylate monomer!?!....or pump your own gasoline?
Acetone is the most beguine chemical there is next to water. It doesn't even cause smog.
But to answer your question specifically, no there is no chemical less hazardous then acetone that will dissolve the fairly toxic cyanoacrylate monomer and not react with it.
Re: Toxic?
Had to smile, Acetone is one of the last chemicals I would worry at all about. Chances are your wife uses it regularly (finger nail polish remover). The ONLY thing I concern myself about when using it is the flammability.
