Veritas - Innovation in Tools
Depth stop drilling tip
It is a common need to drill a pilot hole and not punch through the other side of what is being drilled, or just to drill a hole of some approximate depth. A "flag" on the bit, made from a thin strip of masking tape, is a well know solution to the need.
As the drill drills it makes chips that gather around the hole. When the flag sweeps them away the drill has reached the fixed depth.
Re: Depth stop drilling tip
Has always been my method too.
TomD
If the drill is sharp it should go in the same amount for the same number of turns. With a motor drill it is hard to count low numbers though fine for winding up traces and that kind of thing. But the reason I use an egg beater is because I know how deep it will drill.
Forrest Addy
It's called a "flag". I learned it in 8th grade wood shop in 1954 and it's still a good trick. When the flag sweeps away the chips, stop drilling. Good for you for independently re-discovering it.
David Charlesworth
It's a good idea to check the flag from time to time, it can get pushed further up the drill !
David
good point
If drilling doesn't stop when the crumbs are first swept by the flag the flag will be pushed up the drill. After a few of these events the drill will be found poking out the other side of where the holes is being drilled (so I am told :) )
I could write a book on how to screw up building furniture. As I think about it that might be a useful book or series for a magazine.
Joe in a Cleveland suburb
Does this door have finish applied to it? Just the panel, right?
Thanks.
Freddie Fumbles...
Grant in Iowa
I recall reading Popular Mechanics in the 70's. There was a monthly comic strip/ tip that featured the main character Freddie Fumbles. There'd be two frames usually with the first showing him "fumbling", then the second showing him using an elegant solution. Your flag solution was, I believe, featured one month.
By the way, I appreciate your humbleness in sharing. We each make many mistakes a day, and it is nice to be reminded of that once in a while. Too many people try to hide their mistakes these days.
Regards,
Grant in Iowa
