Wierd planer-wish it existed
I got up way to early this morning. Went back to bed after a short spell on the forums and had the wierdest dream. I had a new planer. It was specially designed for small fragile work. The outside was plastic and it looked like the stack feeder on a copier platen. It had 2 infeed places. One was flat like you would feed a sheet of copier paper into the feeder. The other was directly above this which looked like the outfeed of the same copier paper feeder. You fed the work through the bottom for thicker stock removal and through the top for really fine stock removal.
Anyway in my dream I was feeding a piece of Ebony that was about 2'x3" and half white and half black with huge voids running at an angle from corner to corner so you only had about an inch of solid wood in the middle. These voids were open about 1/2" on each end and were ragged V shaped. Anyway I fed it through the top fine feeder a half dozen times flipping the wood each pass and it thinned it out and left an almost polished finish on both sides which didn't require any sanding before the finish.
Don't know how this thing worked but I want one. Oh it said in the manual that the blades were set at a more blunt angle to aid planing highly figured wood.
