Spice Box- applied finish
Finally worked out a finish for the boxes. In the past I had used garnet shellac over burnt umber pigment stain. The new batch of shellac is too yellow. I cured the problem with some burnt umber glaze. The picture is more red than in reality. I am probably getting some illumination from reflection off the red brick. As the color ages it should turn out as I wished.
Re: Spice Box- applied finish
Spectacular all the way around!! and a Question
That is really good looking. Thanks for sharing with us.
I should know the answer to my question, but apparently I have not been paying enough attention. How do you address the cross grain connection between the side and the base molding?
Jesse Cloud
Great project. Thanks for sharing the build. I learned a lot.
Looks really nice, Bill!
Stuart Hough
Something to be admired through the ages!
Re: Spectacular all the way around!! and a Questio
William Duffield
Well, I'm notBill, and I don't know how he addressed this general issue on these particular spice boxes. However, the problem is universal for mouldings over carcass construction. The most common way to deal with it is to glue the front third of the moulding, so the miter won't open up in the front corners, and nail or brad the center and back of the moulding. The nails are flexible enough to hold it in place without snapping it off. I've seen much more complicated methods. IIRC, an article by Garrett Hack in FWW showed how he attached the back of the moulding with a sliding dovetail. A pin slot was cut in the back side of the moulding and fitted to a matching tail that was screwed to the carcass. A slightly less complicated trick just uses the head of the FHWS instead of the wooden sliding tail.
Some people nail the moulding on, front center and back, sometimes with the front glued and sometimes not. A nail and glue on the front third means you don't need to clamp it while the glue dries, but it also means you have another nail hole to putty, up front where it is more visible.
Some others just glue it on all the way across, and hope it doesn't come off before the check clears. :(
The molding toward the front is glued to the case (about half the length or 5") and nailed in the back.
joe in a Cleveland suburb
Beautiful. Bill you do fantastic work.
Thanks for sharing this with us.
A note about spraying
I used a 20 wt/wt% solution of shellac in ethanol and sprayed a wet coat. It was hot and the solvent flashed quickly and was dust-free in seconds.
The box sits on a Lazy Susan for spraying. This arrangement allows easy positioning of the box. The spraying strategy is to avoid overspray on something already sprayed. I did the top edges first angling the spray downwards. Next the top, spraying front to back. Then the underside of the top angling the spray upwards. Then the sides.
The only reason I used shellac is because it doesn't yellow with age and that is important for the Line and Berry decoration. I used blond Zinsser for the panel, garnet for everything else. If it was simply a walnut box I would have used varnish. I like the luster of varnish on walnut.
For Joe....it took less than 60 seconds to spray the box. The result is glass smooth. The low odor of ethanol is such that no one a few feet away would detect that I was spraying. A "green" neighbor should be happier with spraying shellac than 2,4-D.
Sgian Dubh
Barry, another method to that outlined by Bill is to make a separate plinth with the moulding attached to the plinth, then attach the carcass to the framing of the plinth as illustrated below. The rear rail is frequently optional. There are a range of variations a designer maker might incorporate to the arrangement. What you see sketched is therefore just one possibility, which naturally doesn't suit all circumstances. Slainte.
Re: Lazy Susan Tips
William Duffield
The finishing platform I use started with a 12" ball bearing Lazy Susan sandwiched between two sheets of 3/4" plywood.
http://www.woodcraft.com/Product/02Z51/Triangle-Mfg-Flat-Round-Lazy-Susan-12-516-Thick-Capacity-1000-lbs.aspx
The top ply is round and the bearing is centered on it, so it doesn't have a corners to knock stuff off the bench. The bottom ply is rectangular. It has two short 3/4" dowels that protrude through the bottom, and carefully spaced to engage a pair of dog holes in the bench. This keeps the platform from accidentally slipping off when loading or unloading and rotating what I'm spraying. Since my dog holes are evenly spaced around the perimeter of my bench, I can position the platform in several different places on the bench. If you don't have dog holes, just screw a cleat to the bottom and clamp it in one of your vises. The bottom ply also has two more holes, one to hang it on the wall when it's not in use and the other to allow access to the screws that attach the top ply sheet to the bearing. The function and location of this hole becomes immediately obvious to anyone who has used one of these bearings, so I won't try to explain it here. Sizes of the sheets of plywood are arbitrary, but the top one needs to be at least large enough to support the legs of a chair.
I used a combination on this small case
What I would call the feet were fastened to a frame as you illustrated (yours is the best drawing of this arrangement I have encountered). The tiny cove molding was glued and nailed to the case side. I needed to nail it to the case side to hold it tight to the case side. On a larger case I would have done as you illustrated.
Re: I used a combination on this small case
Sgian Dubh
Bill, There are a range of permutations for making plinths based on the sketch I drew, and it's just a case of finding what's suitable for a particular job. It's not always the case the moulding has to be attached directly to the sides and front of the cabinet. In some cases, the moulding can be the edge of a wider piece fixed to the plinth, and the cabinet sits on top of that. It gives a slightly different look, which may, or not suit a maker's purpose. Anyway, I'm pleased you found the sketch a good depiction of one variation of the arrangement. Slainte.
