I'm building a sports car bed form plywood for my oldest grandsons birthday. My second grandchild, is one and a half younger. However, my son and daughter-in-law want bunk beds. What I'd like to do is build an upper bed in the form of a P 51 Mustang on an angle with the wings and adding steps and a small handrail on the wing showing as steps to allow my youngest to climb into bed with ease
I would be grateful for any of you at WoodCentral may be able to give me..
David, First, I would start by buying a couple of plastic models to try and figure out how you can configure the two together in a way that will work. I'm struggling to see how you can use both without them competing for the same space.
Then, I would suggest, that if the wing will serve as a ladder, it will appear that the plane is banking hard in a turn, so you will only be using the inside portion of the wing going into the floor, then the opposite wing will be either going into the wall, or ceiling. I would also plan on locating it near the corner of a room, so the aft portion of the fuselage is coming out of the wall, leaving the viewer's mind to fill in the missing details. You may need to foreshorten the length, and make it a bit fatter to accommodate a mattress as well.
Then comes the car. The only way I can imagine it being under the plane, would be perpendicular to the plane axis, coming out of the corner behind the wing stair.
I assume you can figure the rest out from here, so by now. Sounds like a fun project.
By tilting the wings as if it were diving or turning back to base, gives me the ability to add steps and a handrail. I'm sure there is a way to blend them with paint. The real question is how to connect the bed to the airplane.
Instead of making the plane into a bed try to introduce them into airplanes of yore by making some models and hang them around the room from the ceiling. When I was younger a friend and his brother made all the planes from models they bought....B29, P40, Hellcat, P51, and several more.
You are right, most parents just want bunk beds for their children, but these beds are for my grandchildren.
Is there anything you wouldn't do for your grandkids? I'm 57 years old with COPD and liver disease. My doctor says I have about 10 or 12 years left. As far as I'm concerned, my grandchildren can have anything they want.
I had the same idea about tilting the airplane as if it were in a bank. The wing is perfect for a ladder. The bed inside the cockpit is going to have to be parallel with the floor. I've thought this through as you did and I'm sure it will work. I'm going to build both beds so that they are easy to disassemble and store. That way my grandchildren's children and their grandchildren will have them for the future. Everything I build is meant to last several lifetimes. Only the paint may need touching up.
