Re: OT cedar decking
Bill Howatt
My reply is the same as John's including the Thompson's which is a product that I normally wouldn't use.
As I mentioned in another thread I have a Western Red Cedar house and I pressure wash it when it needs re-staining. If the stain is real old it will come off and go down to bare wood in most places. Do not pressure wash with a tip that gives a point it will cut the wood. I use a want that provides a fan-like spray and hold it so the fan is about an inch or two wide at the wood. The washer itself is a cheapie Karcher not a gas-powered super high pressure one.
You may find that this leaves little fuzzies on the surface. I quickly go over the washed area with a 5" palm sander with 60 grit disks to remove the fuzzies; it also will clean areas where the old stain didn't wash off. It is not as onerous as it sounds and goes very quickly. After all it's not a dining room table we are preparing. You may even try just the sanding without the power wash.
There are a number of deck cleaners/bleaches you can try too. A scrubbed on solution of TSP and household bleach might even work after sitting for a while.
I guess you have to do what they recommend in many cases: Test in an inconspicuous area.
Bill
