OT How to install tile over Formica?????
The Flip this house I just bought is a disaster, the harder I look the worse it gets.
Help!??
The cabinets are care worn and knotty pine slab doors. The counter tops are post formed Formica laminate in a LOVELY shade or yellow. Mottled yellow. (the 70's are calling looking for their Formica.) I am planning to replace the doors and drawer fronts and counter tops. The problem is the glued yellow laminate on the wall as a back-splash. All the way around. 30 feet of it. And, its behind the base and wall cabinets and window trim. So, any suggestions? How can I stick tile to the Formica? What else can I use? I need some magic here. The neighborhood is not as strong as I thought and my margin is a little thin.
Re: OT How to install tile over Formica?????
Dick Coers
You can get 1/4" thick cement board called Hardiebacker. I'd screw it over the laminate, and then tile.
George Koch
Barry, If the Formica backsplash is glued solidly to the wall, there is no reason you couldn't install the tile right over it using mastic, not thinset. Clean it good with mineral spirits and rough it up with a sander.
Clint Searl
Clint Searl
I like the Hardibacker/fiber cement approach.
walta
How much money will you save by not doing the demo? If you are doing the labor the only cash out of pocket are the dump fees and drywall.
I say put in the labor and do good work and it will show in the finished product.
Walta
