bearing replacement problem
Tool- Bosch 7617 router had a bearing that screeched occasionally, especially during starting
The large load bearing bearing on the bottom of the shaft was a NTN 6004LB. This bearing has "noncontact" seals, what ever noncontact means.
The local bearing store recommended a replacement SKF608 (costing5X the price of what was in there. I heated the router housing to 200 F and cooled the bearing to 15 F and the bearing dropped into its housing, then locked up upon cooling.
Assembled router uneventfully. After assembly the shaft turned freely but with a bit more friction than before. That is to say before if I spun armature it would coast a slight amount and now it doesn't. The new bearing is just stiffer, but smooth. The bearing store said the old one had lost its grease.
Did a test run and after a minute the shaft where the bit goes was hot. Don't know why. I don't think it used to get hot.
