WC Weekend Accomplishments....
Dennis E Peacock
3 Aug 2015
Good Morning Everyone,
This weekend was kind of a lazy weekend for me as the day job has been extremely hard for the past few weeks. I really needed some down time to relax a bit and spend it with family. The LOML and I watched a couple of movies, talked a while, and just had a good time just reconnecting since I've been working a good bit for a few weeks now. It's been way too hot to get in the shop and I'm ever so glad that September is coming because that usually means cooler weather is coming around the bend. I just can't take the heat like I used to.
That's it for me, so what did YOU do this past weekend?
Best of weeks to you all.
Dennis Peacock
Re: WC Weekend Accomplishments....
Daughter called to see if "we" could make a guitar stand. Had her look up designs on line and pick. She arrived last week all set to go with a very simple shallow "S" curve on a flat base. Had a nice piece of 8/4 cherry that would do so I helped her lay out the curves and then she learned how to handle the band saw, spindle sander, and RO. Not perfect, mind you, but nicely done just the same.
By the time it was ready for finishing however there wasn't time to use an oil finish, so we mixed some fresh shellac, tinted it to get the color about 2 shades lighter than she planned, and she learned something about padding shellac.
Then Dad got into the act with the spray gun after which she went "home" with her stand, leveled and then rubbed out with wool & wax to just the sheen she wanted.
Jerry Roberts
acquired about 250 or so additional patio pavers to add to my existing backyard patio. Those things are 9 1/2 X 6 1/2 X 2 1/2 thick. What a job. That really wore me out and they are heavy. Didn't do any woodworking but that's coming up.
Made good progress on the boat. *LINK*
Keith Newton
Which is a fiberglass deck-boat, that I'm turning into a ATV ferry. I finished getting all the waterlogged foam out, and cleaned up, before bonding in a layer of pressure treated plywood with a polyurethane foam in between. This foam was pretty challenging to use. I only had about 30 seconds to get it mixed and spread before it started expanding, which called for some tricks that I'll be using from now on whenever I'm mixing epoxy.
As with most thixotropic chemicals, they kick faster the warmer they are in the beginning, so I kept the jugs in my cooler until I measured each mix. With epoxy, I usually just hand mix with thin mixing sticks which are about 1/8 x 3/4 x 10", and I had taken a bunch of those down, but that was much too slow to thoroughly get it mixed fast enough. So what I did, was to cut a tang giving it a shape like a mill-bastard file. I chucked that in a cordless drill, which worked better than any store-bought mixer I've ever used.
Another thing which helped, was that I was using 16 oz plastic cups to mix in, which is what I normally like for epoxy, because they are cheap and disposable. But the new little thing I did, was to pour equal amounts of parts A & B in 2 - 8 oz cups, then pour them into the larger cup together, so they are in there in column, rather than one on top of the other. My mixer didn't then need to bet the bottom part up to the top, so they mixed much quicker this way. Also, while the drill was spinning forward, it seemed that it mixed better if I went around the cup counter clockwise than the other direction, maybe because it pulled in the middle, while still scraping outside. I'll be using this method anytime I mix epoxy from now on.
I also epoxied in a new transom, and got the floor boards cut and laying in place, so my free boat is looking pretty good now.
As for some real woodworking, last week I needed a much longer beam than was locally available, so I joined two 8" x 8"x 14' cedar beams, using a Kanawa tsugi joint, which turned out looking great, and really surprised me by how strong it was. Here is a link to a pic before I did the finish planing sanding, and easing of corners, and Goncalo Alves locking pins.
https://www.flickr.com/photos/7391658@N03/sets/72157656341178178/
Kneale Brownson
Re: Made good progress on the boat.
Kneale Brownson
So driving the stake into the middle pushes the joint together? Very interesting arrangement of mating surfaces.
How'd you cut the beam joint?
Nice work, Keith. I like thetenon that's perpendicular to the main tenon. You had to square out those pockets and I'm wondering what combination of techniques you used.
Re: How'd you cut the beam joint?
Hank Knight
Keith,
I was wondering about the perpendicular tenon too. Is it actually a tenon, or is it a key inserted into a mortise cut into both sections of the beam? If its a tenon, how did you cut it? Nice job, however you did it.
Hank
Grant in Iowa
Keith,
Nice report, and you accomplished more than I did over the weekend.
I do wonder about the strength of such a joint in Cedar. Cedar has a tendency to split easily, and I just wonder if it will hold up to your intended use. Might be all bluster on my part, but I'd hate to see it fail and hurt someone or something.
FWIW,
Grant in Iowa
I made a template, then duplicated it.
Keith Newton
So I had two identical templates for the router. I then connected them along the top / long edge, so they would saddle over the beam and be easy to square across.
Knifed a scribe, then pencil line. Then I took the template off and used the big 10" Makita circular saw to cut about 1/4" from the line along the long diagonal, and cut right to the line across the grain to remove the bulk of waste. The saw wouldn't cut to the middle, so I drove wedges in to split the rest. You can see the waste standing on the left in the second shot.
For the lower offset diagonal, I made a bunch of 1 1/4" deep crosscuts to chisel out the waste easier. Then I ran the router with a 1 1/8" bearing over bit against the template. It was pretty easy then to use a big chisel to remove the waste between the finish surfaces coming in from both sides. A straightedge between the two would reveal any high spots, and being a little low was not a problem with the 2" flats from the router template.
Sorry I didn't think to take a pic of the open joint, but the ends look like a big T with longer arms than the leg. From the end grain, I ran my regular 7" circular saw along my lines to cut the outline, then used a jigsaw to get close to remove the big waste block under the T arms. I trimmed to the line with a chisel, and multi-tool. This provide a male T shape, which tenons into the female at the other end of the mating part.
For the mortise end, I started by chopping in a little way with a chisel, but then drilled a 1/2" hole near the deep corner, then used the longest blade for my Bosch jigsaw to get close, then popped out the waste, and finished with a chisel.
I cut the mortise for the bottom of the leg of the T a little narrower than the other end initially, so I could set the parts up end to end perfectly straight, then do the final trimming just before assembly. One beam was 1/8" larger than the other, and the client wanted to leave some rough sawn marks, so I didn't want to make an error in measuring, is why I used the above approach. But there was a lot of sticker stain on the surface, that I ended up power-planing it all smooth in the end.
The scariest part, was the first trial assembly. Since I was working up on horses, I couldn't use a big sledge to drive them together, so I put my 3 longest pipe clamps end to end to press it in, not knowing if I could pull them apart. But that turned out being easier than I expected. 4 wedges driven in the ends extracted it easily, and I breathed a sigh of relief.
Keith Newton
Hank, at that point, I was using two hard maple opposing wedges to lock the push the joint together and apart as I tweaked the fit.
After it was all finished, I cut a little tapper in the mortice, then made a nice Goncalo Alves pin to drive in, leaving 1/4" proud with the corners eased on it, as well as the whole joint.
I hope this answers your question.
Keith Newton
Grant, I appreciate your concern, but there is more than meets your eye.
This joint would normally be used as the chord of a truss, with the tenon of a king-post coming down through the middle, and that pin locking it. Then the rafters pushing against it, connecting to the ends of the chord would make two big triangles that would all be locked together. I wish I was getting to do that with this one, but this was an afterthought of the client, so I got to hang it on Friday while the drywall finishers were working in the great room.
I managed to get it up, without even marring their work, and it is touching the wall perfectly at each end. I did reinforce that joint with a long box beam bolted on top, which is hidden in the ceiling space between floors.
Also, I used a 12 VDC winch which I keep in my truck to lift it, using an eye-bolt to hook onto. After it was up in place, I bolted it into the floor trusses also, so I'm not worried about it falling.
I know without a doubt that it will split as the wood dries, and I told them that before ever agreeing to do the work. At this length, I wouldn't be surprised if it even shrinks a little along the grain. I have seen that with green Western Red Cedar before.
Thanks, Keith, I understand
