Mirka "net" sanding discs
Dick Coers
Just got off the phone with a Mirka district rep. I asked about the different "net" products since I found a wide price range on line. They have Abranet, Abranet Ace, Abranet HD, and Autonet. Abranet is $47.50/50 discs at Homestead, Abranet Ace is $41.11/50 discs at Mirka on-line, Autonet is $22.50/50 discs at Mirka on-line, and Abranet HD is $21.07/25 discs on Mirka on-line.
Abranet is their original product. Autonet is identical in all aspects except for the weight of the net. The Autonet has a thinner, more flexible net and was introduced at a price point for marketing towards the high volume users in auto body shops. In the opinion of the rep, it will perform as well on wood as Abranet at grits courser than 400. Finer than 400 and he recommends only using Abranet as it will cut better in those fine grits. Abranet Ace is a new product and uses ceramic abrasives, same net as Abranet. Abranet HD is a hybrid product and is only available in course grits. It is very rigid and is for heavy material removal. All of these products have a sterrate coating, but he could not give me the specific material specs on the coating. His only caution on using Autonet on wood is in applications where you will sand into corners. The lighter weight net will tear more easily than Abranet when banging the edges. A very seldom situation for me. So the next order for me will be Autonet. Oh yeah, don't forget the pad protector if you use the net products. It grips better and protects your sander pad. $19.29/5 at Mirka on-line. From what I read on line, a single pad protector can last for over 300 discs, so not a high consumable. All the prices given are for 5" discs.
