strip stain
strip stain
strip stain
Akhtar
the stains on the chestnut doors, trim etc are inconsistent, or dirty and dull. I am guessing they shellacked the wood. Is there a way to clean the wood of hand oil stains? What about lightening the color? Complete newbie here.
Re: strip stain
Re: strip stain
Jim Hoeller
If it is shellac, denatured alcohol should help clean it. Try as small and inconspicuous area to test.
Re: strip stain
Be careful with denatured alcohol
Dick Coers
Denatured alcohol is the solvent of shellac, it will strip the finish. Maybe what you will need, but I would start with mineral spirits. It will dissolve hand oils and dirt, but not the finish. Nearly all finishes yellow or darken with age. Stripping it off may lighten the color enough. After that, it's a major deal involving 2 part bleach, or some serious chemicals.
Re: strip stain
Start Slow
with a bit of soap and water (soft rag damp with detergent and water - no ammonia) to clean off hand oils etc. before you jump for solvents. Once the rag comes clean allow to dry and see what you've got. As mentioned, shellac will be dissolved in alcohol (also by an ammoniated cleaner like Windex) so you can test your now-clean finish on an inside corner with a clean paper towel and some alcohol. Rub gently and see if you get "color off; a tell tale that it's shellac. If no results, you can use some mineral spirits to remove any grime that the detergent left behind. Allow to dry and again look at what you've got. If it's not a shellac finish over stain, and you really (REELLY) what to lighten things up, you're likely looking at a full-bore refinishing routine that may include stripping, sanding, bleaching to even out the wood tone, then staining, and re-sealing with a new finish film.
