comments....
I've used self-centering punches and drills, but find that they may still drill an off-center
hole. The problem is that this hole may end up on the wrong side of the centre......Indeed, if the Vix-bit is not perpendicular to the work it drills an off-center hole. On the other hand I have successfully drilled hundreds of holes with the Vix-bit for architectural hinges and furniture.
Ideally, one wants a hole that is very slightly off the centre so that the screw pulls the butt hinge tightly against the back edge of the mortice. To do this I locate the mark with an awl.....the problem is if the wood is grainy either the awl or drill can run off center.
In addition to also marking the screw position with an awl, he will only drill the holes on the drill press (which means that the mortices are planned beforehand), pointing out that it is the off-vertical alignment that causes problems........An indisputable fact.
He will also test-fit the screw in the hinge beforehand, and use a chamfer bit to improve the fit where necessary.....given the crappy quality of hinges now days they often must be adjusted. I number them when marking the mortises to account for lack of uniform orthogonal shape and don't bother to file square.
And don't forget driving in a steel screw to cut threads for the soft brass screw.
And at the end, he will polish the tops of the screws to remove machine marks. I usually cam out the screw driver and make new scratches
Yes, his work wins awards......no chance of that on for my work
