Abranet
Abranet
Abranet
Is anyone here using Mirka's Abranet as their daily abrasive instead of traditional ROS discs? Curious about the experience and results.
Thanks,
T
Re: Abranet
Re: Abranet
Rick Christopherson
I've always used automotive grade cloth backed disks on my Dynabrade sanders. Because I retired the shop, I have enough of these to last a lifetime of hobby work.
A couple weeks ago I was given an Abranet disk to play with. I was pretty surprised that this single disk lasted for the entire project. It outlasted my normal cloth-backed disks. It was 120 grit, which is what I normally use on my sander for nearly all sanding work. I rarely need to go up to 180 grit with a Dynabrade, so your results with an electric may vary.
Re: Abranet
Re: Abranet
David Yoho
Tommy, while I have only very limited experience with it, I do know a fulltime professional that's been using it for quite some time and swears by it. He also uses pneumatic sanders over electric.
Re: Abranet
Yes
I use them on my Festool sanders, in grits from 80 to 600. I use an intermediary H&L pad (about 1/8" thick) between the disk and my sander's pad to insulate the pad from heat that could melt the hooks and cause early failure.
Re: Abranet
Supplier?
Dick Coers
I had a bookmark set on an industrial supplier with great prices, but the address no longer works. Should have ordered when I had the chance.
Re: Abranet
Found they make an Autonet, much cheaper
Dick Coers
Anyone use the Mirka Autonet instead of Mirka Abranet? Close to half price of Abranet at Homestead. It's $22.19 for 50, 5" discs of Autonet at a couple of suppliers on-line.
Re: Abranet
Careful
That looks like an automotive product designed by body shop use that may not do well on wood. I'd call a supplier and ask a few question first or get in touch with Mirka direct.
Re: Abranet
Re: Abranet
Thanks all. Took a good look at the new Mirka ROS and liked what I saw (except the price). If I end up taking the plunge, I'll report back.
T.
