OT-Wi-Fi
Tom
How would I go about improving the signal in our home? Some parts of the house it is hard to get a good signal.
Thanks!
OT-Wi-Fi
Tom
Thanks!
Re: OT-Wi-Fi
George Koch
Tom, Get yourself an extender compatible with your existing Wi-Fi and install it near the end of your signal.
Re: OT-Wi-Fi
Stuart Johnson
You might want to check LinkE Mini. You plug it into a wall outlet, connect it to the router with an ether net cable. Another unit is then plugged into an outlet anywhere in the house and then connected to the computer with another cable. The signal is sent over you house wiring. It's not wireless but does work well.
Re: OT-Wi-Fi
If by chance you have Mac (I do) then upgrading from an Airport to an Airport Extreme really helps.
T.
Re: OT-Wi-Fi
Stuart Hough
I moved my wi-fi router to a spot near the center of the house and it made a world of difference. Strong signal throughout, and additionally, I can use my new outdoor wi-fi enabled outdoor speakers by the pool with no signal problems.
Re: OT-Wi-Fi
We live in an old house - radio signals, it turns out, don't penetrate plaster very well. We tried an extender (pick up radio signal, amplify and retransmit), but wound up running cable to the opposite corner of the house and putting a router with wi-fi there.
Re: OT-Wi-Fi *LINK*
Jim Dillon
Tom. another vote for a Wi-Fi extender. I've had luck with this model which takes the signal from my modem/router through two log-cabin walls and a steel garage door 40 feet away to my shop.
Jim
Netgear Extender
Re: OT-Wi-Fi
Ran a 5-E cable for the rounter in my office on the lower level up to the main floor and hooked in an Apple airport. Everybody's happy now. [with the wi-fi anyway
Re: OT-Wi-Fi
I tried two wi-fi extenders and was not entirely happy with either.
Another option which is more trouble to set up but bulletproof - use a second wi-fi router connected with an ethernet cable. This is especially good if you have a long distance or many obstructions since it doesn't rely on getting a good signal from the existing wi-fi router. Maybe wi-fi extenders can be bought with this feature these days; if so configuration would be easier than using a second router.
With an ethernet cable the distance doesn't matter. I ran cat-5 cable underground in conduit about 300 ft to my shop down the hill and configured both to use the same id. Wi-fi connection is seamless between both locations.
Re: OT-Wi-Fi
walt
Powerline networking. It seems to work well on reasonably modern electrical systems. I'd be doubtful about knob and spool though ;-) Several manufacturers produce kits, you need at least 2 pieces, One to plug your router into, one to plug your PC/printer/WiFi repeater/whatever into. It seems simple to add more outlets. I don't use powerline networking but use something called MoCA which is similar but uses cable TV coax instead of AC power lines. Some cable TV vendors use MoCA for things like multiroom DVRs and to deliver pay-per-view content to set top boxes.
I would take speed claims for for both powerline networking and WiFi with a grain of salt. Both are slowed by less than optimum infrastructure. Thick masonry walls, metal studs, microwave ovens and certain older cordless phones are some things that can impede WiFi signals. Plugging a powerline network adapter into a surge protected outlet will cause it to not work.
http://www.cnet.com/how-to/home-networking-part-7-power-line-connections-explained/
Re: OT-Wi-Fi
David Yoho
My computer is upstairs where the broadband connection hooks to the modem and wireless router. My computer connects via a cable. Everything else in the house (Tivo, smart TV, wife's laptop, Kindle, and smart phones) use WiFi. We had trouble streaming Amazon movies on the TV downstairs, so I purchased an extender, which I setup and plugged in downstairs. Now the signal is good enough for the TV to stream movies without stopping to buffer and nothing else seems to be dropping the signal like it was doing before.
Re: OT-Wi-Fi
John McGaw
As mentioned, having your WI-FI router in a central location can be a great help but if that isn't enough an extender can be a real help. My house is loaded with metallized reflective insulation which blocks radio signals pretty effectively so I finally resorted to an extender to get a stronger signal in the basement rooms. I bought a "NETGEAR AC750 Dual Band Gigabit Wi-Fi Range Extender (EX6100)" from Amazon. This is rather more expensive than others but I really wanted to have the dual-band capability and decided to bite the bullet. It seems quite effective and was easy enough to set up. If you wanted only 2.4gHz coverage there are much cheaper units available.
Re: OT-Wi-Fi
Stuart Johnson
What is the difference between the dual band and single(?) band? What is the advantage of one over the other?
Re: OT-Wi-Fi
John McGaw
'Standard' Wi-Fi operates in the 2.4gHz band of frequencies but there is also a second 5.0gHz band which tends to be less crowded, more free of interfering devices, and faster. Modern wireless devices will work on either band but can work on both together making much faster data flow possible. Think of it as filling a swimming pool using two hoses rather than one with one hose being thin and a bit kinked and the other fat and straight -- you can get the job done with either of them but both working together will be the optimum solution.
Of course if the remote device doesn't support both bands or doesn't need high speed for its tasks or if the overall data flow in the network is naturally constrained using the slower cheaper single-band will be fine but if you are streaming HD movies or transferring big data to/from a local server you will probably want all the speed you can get.
Ditto
The downside is that you now have two networks, and your phone or iPad has to switch between them when you walk from one zone to the other.
Re: Ditto, but...
Ellis, you can configure the second router as an access point rather than a router and it will be seamless with the first router. That's what I did when I put wifi in my shop. I ran an ethernet cable underground to the second wifi router, set it to access point mode and to the same SSID, and have continuous dual-band coverage on the same network. (I tested it once walking from the house to the shop)
It is great to have full-strength wifi in and around the shop!
BTW another problem I had to solve was cell phone coverage in the shop. With a metal roof and walls almost 8" thick I could not get a reliable cell signal. I tried an expensive cell signal extender/amplifier and it was not acceptable since even the cell signal outside the shop was poor because of a hill. I finally installed something called a "femtocell" - it connects to broadband with an ethernet cable and appears on the Verizon cell network as a tiny cell tower. It will even work in areas that have zero cell coverage. Since it is actually a public cell tower, it would not be so good for use in an apartment or if you have close neighbors, but the range is short enough that's not a problem here on the farm.
Another vote for Netgear Extender
Our house is double brick and signals do not pass easily though the walls. I have two of these extenders for the wireless modem. They are are pretty cheap and take minutes to set up - essentially they set themselves up.
One boosted the smart TV from a single bar to 4 bars, and the signal has since been excellent (no lag in movies from the NAS and quick Internet). The other extender went upstairs to my office, where I was previously getting signal dropout to my MacBook Pro and struggling to get a signal at all to my iPad. Both now work well.
